Date/Time: Wed, 09 Sep 2026 16:13:29 +0000
[User Discussion] - DATA file in Google drive
View Count: 2018
[2013-11-26 21:54:48]
Moti - Posts: 63
Trade with Sc from few PC, to get all study/ chart updates
Can DATA file reside on Google Drive ?
Thank you,
Moti
[2013-11-27 00:08:13]
You can't be serious about this. So there is actually a Google drive out there now? This must be some NSA scheme to get people to hand over all of their data to them.
[2023-08-10 20:37:15]
HumblyTrading - Posts: 222
You were so right! :)
[2023-08-13 20:58:33]
ForgivingComputers.com - Posts: 1238
Using Google Drive or Microsoft OneDrive to share single documents (e.g. Word, Excel, etc.) between PC's is fine. However, you do not want to share the SierraChart folder, nor just the Data folder. Files can be locked by one system, preventing the others from using it. They could all theoretically get caught in a "Deadly Embrace" where they are all waiting on each other and nothing gets done.
While it may be technically feasible when only one instance of Sierra Chart is using the shared folder, every time Sierra Chart writes to the data folder a copy is sent to the cloud drive increasing network traffic. As SCID files can be very big, you don't want these being copied repeatedly. (I am not sure if they stay in sync incrementally or by copying whole files.) There is no selective syncing of Google drive.
Also, multiple instances should never share the same data folder.
If you want to migrate your data to a new PC, you could use the Google network drive to copy the c:\SierraChart folder but don't leave it connected as a live network drive.
A safer alternative that would keep your various systems in sync is to use something like FreeFileSync, where you can define the paths and types of files to copy or mirror back and forth. Then you could treat Google drive like a master drive and use it to replicate to other systems.
[2023-08-13 23:36:40]
Thank you. That’s my exact setup. I was just laughing about how you guys correctly called all the privacy issues with Google and many other issues with Microsoft.
Are you still working on a standalone OS?
It is probably inevitable.
Thanks again.
