Date/Time: Thu, 02 May 2024 07:58:30 +0000
Market Depth Hist. Graph
View Count: 665
[2019-05-22 18:58:02] |
conr - Posts: 204 |
I have a question on why there is a difference in shading when I go from half screen to full screen. Please take a look at the 2 images. They were grabbed within seconds of each other. Look at the density of the first image when on half screen and then I maximize the chart and the shading disappears. The third image is of my settings.
screen 1.PNG / V - Attached On 2019-05-22 18:56:43 UTC - Size: 165.1 KB - 272 views screen 2.PNG / V - Attached On 2019-05-22 18:56:59 UTC - Size: 113.03 KB - 259 views settings.PNG / V - Attached On 2019-05-22 18:57:08 UTC - Size: 25.03 KB - 212 views |
[2019-05-23 23:02:23] |
This is because the Market Depth Historical Graph determines the High and Low values (which in turn are used to determine the colors) based on the visible data, not the from the entire data set. Refer to the information here for how this works: Market Depth Historical Graph: Block Coloring Logic Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-20 22:41:50] |
John - SC Support - Posts: 31293 |
We have added a new option to the Market Depth Historical Graph that will allow you to determine the Minimum and Maximum depth levels either from the visible bars (as it works now), or from all the bars in the chart. This will be in the next Pre-Release - v 1979. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
