Date/Time: Fri, 03 May 2024 07:47:11 +0000
Changing a currency pair
View Count: 727
[2019-05-20 18:31:15] |
User96441 - Posts: 16 |
You used to be to change a chart from say GBPUSD to EURUSD by typing EURUSD on a the GBPUSD chart, but it does not seem to work any more, how do I do this now? Thanks |
[2019-05-20 20:29:14] |
John - SC Support - Posts: 31334 |
This still works. Refer to the documentation here, and the section after it: Changing the Symbol of a Chart: Quickly Changing the Symbol of a Chart to a Symbol for which a Data File Exists Note that there are two different processes depending on whether the data file already exists or not. Or you can always just use the safe method and use the "/" (slash) key first for any symbol entry. Also note that you need to have the option for Global Settings >> General Settings >> Support Symbol Entry from Chart Window enabled. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
