Date/Time: Fri, 03 May 2024 18:38:52 +0000
Support and Resistant chart
View Count: 475
[2019-05-20 16:25:59] |
User438264 - Posts: 3 |
I cannot find out how to set up simple support and resistant chart. Can you extend my free trial period to see if it even works. How do I set up S/R chart?
[2019-05-20 17:49:43] |
We have reset the trial for your account but we need to know specifically what you require in regards to " simple support and resistant chart". This is not clear enough. We need more details.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-20 17:49:48
