Date/Time: Fri, 03 May 2024 21:55:25 +0000
Same size control bar buttons & clear recent/current trades
View Count: 616
[2019-05-20 15:53:26] |
User835963 - Posts: 18 |
Hello guys," 'use the same size for control bar buttons" feature did not work since release 1917, meaning when applying the feature still showing in different sizes is there a way to have a universal feature where one can clear recent trades for all charts in chartbook and the same for current trades or one feature where it clears all recent and current trades and recenter the DOMs for all the charts in one chartbook? thanks |
[2019-05-20 17:12:26] |
The option to set control bar buttons to be the same size definitively does work. The current version is 1919. Make sure you have set it on the control bar which is visible. The answer is no to your other question. There is simply no possibility of this ever being supported. It is technically impossible with the current design. It never never will come. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-20 17:13:19
[2019-05-20 18:04:29] |
thanks for the quick response, I'm running the current version 1919 and still running into the same issue, it is not a big deal but I thought I would report it to you guys please check out the snapshot attached and let me know what am I doing wrong? s://www.screencast.com/t/36gqdtuBp too bad for the other feature request, it would have been great especially when using keyboard short cuts and being able to clear all those fields and recenter all doms all at once but it is what its!! thanks |
[2019-05-22 05:15:12] |
The problem is obvious and as we said. As we said in post #2 above, make sure you have set the option to use the same size for control bar buttons in the Customize Control Bar settings window for that specific control bar. There are 8 different control bars, and you are setting it clearly on the wrong one.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-22 05:15:57
[2019-05-22 09:35:18] |
dude I have no idea what are you talking about, in the snapshot above s://www.screencast.com/t/36gqdtuBp it clearly shows I have it set for control bar 5 and the customization window is for the same number control bar besides, you did not address the issue about disappearing buttons...just so you know the only thing I did to prove i'm not imagining things is I reinstalled version 1915 where everything was working just fine without making any changes to my control bar settings...the following snapshot shows that if you care to see, s://www.screencast.com/t/TlIzTRLFvp I don't care anymore. |
