Date/Time: Fri, 03 May 2024 04:24:04 +0000
ES symbol for Gain Capital
View Count: 695
[2019-05-20 14:42:08] |
User180814 - Posts: 45 |
I can not get a data feed this morning. Has the symbol changed between Gain and Sierra for ES emini contract. I am getting an error Symbol unknown click for symbol infor. Fix reject reason unknown contract. Is there a new symbol? I did not even see an ES symbol for the emini when I went to search for it under chart setting symbol find. Thanks for your help Sierra.
[2019-05-20 15:56:11] |
We do see the ES futures symbol listed for Gain Capital. Can you tell us the exact symbol you are currently using? We want you to update to the current version: Global Symbol Settings: Update Global Symbol Settings This will also cause the symbol settings to be up-to-date. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-05-20 16:03:53] |
What is the es futures symbol listed for Gain? I am using ESM 19
[2019-05-20 17:10:43] |
That is correct but it does not contain a space.
[2019-05-20 18:18:44] |
Thank you I did what you suggested and it worked. Regards, Marc |
