Date/Time: Sun, 05 May 2024 22:20:03 +0000
Can sc.GetStudySubgraphDrawStyle() be added?
View Count: 693
[2019-05-19 08:08:17] |
@sstfrederik - Posts: 403 |
Hi, Working on a project and thought I could get the drawstyle of another study SG, but I do not see the function. I do see sc.SetStudySubgraphDrawStyle. Can sc.GetStudySubgraphDrawStyle also be added? Thanks Frederik |
[2019-05-20 19:40:01] |
Yes we will do this if there are no complications.
[2019-05-26 10:20:18] |
Any release number on this addition? Thanks for the good work that has been done.
[2019-06-20 03:25:37] |
dtl-saw - Posts: 79 |
I would appreciate this function for my studies as well. No hurry here, but please let us know once it's ready to use. |
[2019-06-20 09:43:28] |
It is already there. Check the header file
