Date/Time: Mon, 06 May 2024 00:01:38 +0000
2nd instance data problem
View Count: 577
[2019-05-18 19:01:38] |
cmb999 - Posts: 211 |
1st instance: CQG Trading, sc realtime data 2nd instance (on different pc): SC Data, getting error with the same chartbook from first instance SC Data - All Services | Starting real-time market data updates for: F.US.BP6M19. ID: 2 | 2019-05-18 14:53:36.505 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: F.US.BP6M19 | 2019-05-18 14:53:36.505 SC Data - All Services | Requesting security definition data for: F.US.BP6M19. ID: 2 | 2019-05-18 14:53:36.505 No historical data client is currently set to download historical Intraday data for F.US.BP6M19. | 2019-05-18 14:53:36.505 Real-time Intraday chart data file updates started for F.US.BP6M19 | 2019-05-18 14:53:36.505 Opened cached Intraday file: C:\SierraChart_AMP\Data\F.US.BP6M19.scid | 2019-05-18 14:53:36.506 Intraday chart data file opened for F.US.BP6M19 | 2019-05-18 14:53:36.506 |
[2019-05-19 14:20:57] |
sorry, needed to switch to different symbols for SC Data-only (non-CQG) feed on 2nd instance
[2019-05-20 17:52:59] |
John - SC Support - Posts: 31379 |
Yes, what you state is precisely the issue. For information on how to change the symbol for a chart, refer to the following: Changing the Symbol of a Chart: Changing the Symbol of a Chart or Trade DOM Through Chart Settings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
