Date/Time: Tue, 30 Apr 2024 21:09:46 +0000
historical chart long loading
View Count: 547
[2019-05-18 15:26:06] |
sierrasimon - Posts: 51 |
Hello, I have 2 questeions about that chart I send you. 1. Why does it load symbols that are not relevant? the loaded day are from 2018, but it loads contracts from 2019? so it loads longer than it should. 2. Calculating the studies takes about 5 minutes. I can't identify the reason. Can you help with that? Thanks |
ES minimal Trading.Cht - Attached On 2019-05-18 15:21:04 UTC - Size: 598.19 KB - 224 views |
[2019-05-20 18:45:35] |
1. The chart is loading additional symbols since the charts are defined as Continuous Contract charts, and you have selected the current front month contract for the symbol of the chart (ESM19). If you only want to the see the symbol related to the time period you selected (such as ESM18), then just select that particular symbol and do not use the Continuous Contract option. You will find the information on turning off the Continuous Contract here: Continuous Futures Contract Charts: Continuous Futures Contract Rollover Options 2. The only thing we can say is that you have a lot of Volume by Price studies on your charts. These are intensive calculations and this is most likely the reason why it is taking awhile. You can review the information at this link to see about potential improvements: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often And review this section in particular: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.35 - Volume by Price Study Configurations Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
