Date/Time: Fri, 03 May 2024 09:13:19 +0000
Requesting a Simulated Futures Trading Service account
View Count: 1017
[2019-05-11 20:03:28] |
stphnlwlsh - Posts: 26 |
Just sent my log in via the "send for analysis" button on my account. Unknown symbol, market data requests not allowed. I kept all of my same symbols as I've been using SC data for 2-3 months now. Date Time Of Last Edit: 2019-05-11 20:34:10
[2019-05-11 23:39:18] |
You are not using the correct symbols for the Simulated Futures Trading service. You need to use the symbols in File >> Find Symbol: https://www.sierrachart.com/index.php?page=doc/helpdetails1.php#Symbols Did you also want to trade BATS symbols? It is not set up for BATS symbols but it could be. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-11 23:39:38
[2019-05-12 00:25:40] |
Re: BATS, yes please. Re: Wrong symbols, I did the symbol lookup and did not receive an error, but data still did not refresh live with ESM19 and CLM19. If they issue remains tomorrow night when the session opens, I'll let you know. Thanks for the help thus far. |
[2019-05-15 12:24:56] |
Data does flow on the different symbols. Thanks. Waiting on BATS still if you don't mind. |
[2019-05-15 20:01:23] |
Ok so we understand you are no longer having a problem receiving the real-time future data. That is good. That of course would be due to CME market data authorization issues. In regards to BATS, we will try to get that done this evening. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-06-03 17:31:02] |
Sorry about putting this on the ticket... I realized this weekend that I didn't need full market depth for numbers bars charts (my primary chart), so I switched over to the 'Full CME Group (CME, CBOT, COMEX, NYMEX) for nonprofessional Trading accounts' data feed. Symbols are not known any longer and I'm not getting live data for my evaluator account longer. Can this be fixed, please? Thank you! |
[2019-06-04 03:55:27] |
We would not expect a problem with this. This type of issue has been worked out quite a long time ago. But maybe there is some scenario that we are not aware of that is occurring. Provide us the information below: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-04 03:55:43
[2019-06-04 12:32:38] |
Opened up this morning, and live data was flowing again on the symbols for the evaluator. I'm not sure why it wasn't working yesterday. I did go back and activate my original data feeds to see if that fixed the issue. Is data possible flowing on those instead of the intended non-market depth one? Sorry if this is a dumb question. I'm not sure how the back side of things work. |
[2019-06-04 17:53:41] |
You should be getting market depth data now as you have the exchanges active with market depth data.
[2019-08-20 15:25:51] |
Can my account be reset to $50,000 please ?
[2019-08-20 16:53:18] |
We need to create a new account. We will do that. Account balance adjustments will be coming soon though.
