Date/Time: Fri, 31 Jan 2025 10:41:01 +0000
URGENT
View Count: 780
[2019-05-01 16:56:20] |
Luke - Posts: 142 |
Both Amp and CQG asked me to contact SC support, because they could not solve my problem, even through AMP remote support. I am not able to receive realtime cme/cbot data, everything was fine until yesterday. Missing intraday data will be updated when I click connect, but I get an orange popup with the message: symbol is unknown, realtime data for instrument not allowed. No realtime data transmitted. I have two CQG logins for the same account on two different PCs, one connection is fix, the other webapi, both the same problem
[2019-05-01 17:19:58] |
Luke - Posts: 142 |
I was able to connect again just now, can it have anything to do with the time settings? I am located in Thailand, connection was working just after midnight some minutes ago, may 2. My Pcs are set to Bangkok time, SC timezone is Chicago.
[2019-05-01 18:19:26] |
This is an issue your broker will have to resolve. We have several reports of this issue for users using CQG. It relates to market data authorizations: CQG Trading Platform Service: Market Data Authorizations for Symbols/Exchanges Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-05-01 20:22:02] |
User13668 - Posts: 294 |
I have exactly the same issue and as at right now AMP have still not resolved it with CQG, although it all worked fine pre 1 May. It is not yet the 2nd May where I am, so will be interested to see if the midnight thing gives me a fix. |
[2019-05-01 21:29:49] |
User138602 - Posts: 169 |
I intend to go AMP CQG, right now i am using AMP Rithmic. Will i encounter this problem when i simultaneously use SC exchange datafeed?
Date Time Of Last Edit: 2019-05-01 21:34:00
[2019-05-01 21:30:03] |
At this point, CQG and your broker need to resolve this. This is out of our control and we cannot help with it and we will not provide further help.
[2019-05-01 21:30:47] |
Will i encounter this problem when i simultaneously use SC exchange datafeed? You will definitely not have this problem in this case.
