Date/Time: Tue, 04 Nov 2025 14:57:36 +0000
Clarification - sc.AddACSChartShortcutMenuItem()
View Count: 2864
|   [2013-04-10 11:06:53]     |
| ejtrader - Posts: 688 |
                SC Team - Wondering if the return value for this function - any time going to be "0"? Just trying to make sure the conditions are covered in the ACSIL code. sc.AddACSChartShortcutMenuItem() <0 - un-successful >0 - successful (and returns the actual ID) 0 - Is this a possible return value? If so - what does this indicate? Thanks Date Time Of Last Edit: 2013-04-10 12:18:25
|   [2013-04-11 04:48:07]     |
                Updated documentation for this can be found here: http://www.sierrachart.com/index.php?l=doc/doc_MouseAndMenuInteractionFromACStudy.html#scAddACSChartShortcutMenuItem Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
