Date/Time: Tue, 04 Nov 2025 14:57:28 +0000
Trade Activity Log table not respecting National Language Settin
View Count: 2636
|   [2013-04-10 10:22:16]     |
| User42282 - Posts: 41 |
                Hi, as documented, spreadsheets follow the settings of National Language Settings in Windows (e.g. decimal separator). Unfortunatelly, this is not the case for all the tables generated by Sierra, such as "Trades" list in Trade Activity Log. This is very uncovenient when you want to use the data for further analysis. Any idea? Thanks Mirek  |
|   [2013-04-10 17:08:42]     |
                Yes, this is true.  It cannot be changed.
                 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
