Date/Time: Fri, 31 Jan 2025 03:15:11 +0000
Won't connect to Datafeed
View Count: 1057
[2019-04-09 16:56:48]
Sky_Davis_ - Posts: 9
The data feed was working just fine for me until I restarted Sierra. Now its saying "Socket is closed".
I am using TD Ameritrade data. The ticker I'm trying to use is the ESM9.
[2019-04-09 16:56:58]
Sierra Chart - Max - Posts: 5780
Provide a copy of the Message Log by following these instructions:
Sierra Chart Support
[2019-04-09 18:20:01]
Also the correct symbol is ESM19.
Be sure to refer to the post above as well to provide us the Message Log if you still have a problem.
Date Time Of Last Edit: 2019-04-09 18:20:17
[2019-04-09 18:27:10]
Hi, the messsage log can be found below.
TD Ameritrade | An HTTP request did not successfully complete. Request ID: 8. Requested script: PriceHistory. | 2019-04-10 10:01:38 *
HTTPS connection ID:8 to apis.tdameritrade.com:443 for request ID:8 (1) | Write in progress. Shutdown being delayed. | 2019-04-10 10:01:38
TD Ameritrade | Streamer finished. Request ID: 2. | 2019-04-10 10:01:38
HTTPS connection ID:2 to streamer-ext-bin.tdameritrade.com:443 for request ID:2 (2) | Shutdown started. Waiting for graceful close. | 2019-04-10 10:01:38
TD Ameritrade | Disconnected. | 2019-04-10 10:01:38
Disconnected from TD Ameritrade. | 2019-04-10 10:01:38
HTTPS connection ID:8 to apis.tdameritrade.com:443 for request ID:8 (1) | Write has completed. Shutdown being performed. | 2019-04-10 10:01:38
HTTPS connection ID:8 to apis.tdameritrade.com:443 for request ID:8 (1) | Shutdown started. Waiting for graceful close. | 2019-04-10 10:01:38
HTTPS connection ID:8 to apis.tdameritrade.com:443 for request ID:8 (1) | Socket gracefully closed by remote side. | 2019-04-10 10:01:38
HTTPS connection ID:8 to apis.tdameritrade.com:443 for request ID:8 (1) | Closed. | 2019-04-10 10:01:38
HTTPS connection ID:2 to streamer-ext-bin.tdameritrade.com:443 for request ID:2 (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2019-04-10 10:04:06
HTTPS connection ID:2 to streamer-ext-bin.tdameritrade.com:443 for request ID:2 (2) | Closed. | 2019-04-10 10:04:06
HTTPS connection ID:2 to streamer-ext-bin.tdameritrade.com:443 for request ID:2 (2) | Socket gracefully closed by remote side. | 2019-04-10 10:04:06
HTTPS connection ID:2 to streamer-ext-bin.tdameritrade.com:443 for request ID:2 (2) | Deleting network socket now after delay. | 2019-04-10 10:05:06
Date Time Of Last Edit: 2019-04-10 14:18:58
[2019-04-10 14:11:38]
Hi, can you please help me with this ticket?
[2019-04-10 19:07:20]
You modified the prior message with the Message Log. We need to see the full log. There is a connectivity problem to TD Ameritrade. That is not something we have control over and we really do not recommend using TD Ameritrade because of this kind of issue.
Refer to:
Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem
Really we see that you are using the Sierra Chart Exchange Data Feed, so just follow the instructions here to directly connect to SC Data-All Services and just connect to Ameritrade once a month:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#ConnectingOnlyOnceAMonthToTradingAccount
This will resolve the connectivity problems.
So you need to set Global Settings >> Data/Trade Service Settings >> Service to SC Data-All Services.
Date Time Of Last Edit: 2019-04-10 19:10:50
[2019-04-10 19:08:38]
The prior post has been updated.
[2019-04-10 19:28:20]
Thanks. It works now. Just FYI, I edited the Message Log because i didnt want my IP Address to be public.
