Date/Time: Tue, 07 May 2024 10:55:43 +0000
Referring entry price
View Count: 1052
[2019-03-20 23:49:38] |
JDMontero - Posts: 34 |
Hi. Im working on a Trading system based on alert conditions and would like to Refer entryprice To SellExit at Entryprice + DailyATR*3 How could I do that? Specifically the part of referring entryprice. Regards. |
[2019-03-22 08:54:49] |
The only way in this case to do this, is to use the Spreadsheet System for Trading study: Spreadsheet Systems, Alerts and Automated Trading You can access the information with this cell: Spreadsheet Systems, Alerts and Automated Trading: Last Entry Fill Price [J48] Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-22 08:55:31
[2019-03-22 16:38:46] |
Ok that worked. Now I need to refer to the ATR at the entryprice. Suggestions? VLOOKUP of Daily ATR at last entry date makes the spreadsheet terribly slow. Need to “pick up“ the ATR when the entry happens and keep it in an individual cell, just like all data at J column. Need a way to make “ATR at entry“ efficiently. This response will help me a lot, thanks! Looking forward. |
[2019-03-22 17:41:05] |
Refer to the examples here to see if you can find anything helpful: Spreadsheet Example Formulas and Usage It would be more straightforward to do this using ACSIL: https://www.sierrachart.com/index.php?page=doc/Contents.php#AdvancedCustomStudySystemInterfaceandLanguage Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-22 17:43:56
