Date/Time: Mon, 06 May 2024 17:49:26 +0000
IB with SC trading ETF problem
View Count: 667
[2019-03-20 20:05:44] |
User260560 - Posts: 37 |
Hi there, I'm using Sierra with ib trading stocks without any problem, but I find that when I traded ETFs such as KWEB and GDXJ using chart trading, after i put in a order on the chart, it shows up for a while but then disappears, and I can't drag it to adjust the price either, so the orders didn't get through. Could you tell me what I need to do to fix that please? Thanks!
[2019-03-21 02:25:52] |
You probably need to use this format here which specifies the exchange and primary exchange. Refer to: Interactive Brokers Symbols: Stocks With Specified Exchange and Primary Exchange Format If that works let us know and we will add these symbols to a specific list of stock symbols we have for Interactive Brokers. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-21 02:26:02
