Date/Time: Tue, 04 Nov 2025 14:59:33 +0000
[User Discussion] - Custom spreads or pairs
View Count: 2701
|   [2013-04-10 01:55:57]     |
| User57180 - Posts: 14 |
                Can you tell me if SC offers a way to combine multiple instruments and create studies on groups? Also, is there a way to view the bid volume or ask volume as a cumulative dollar amount traded (ie, buy volume * price traded or sell volume * price traded)? |
|   [2013-04-10 02:44:43]     |
                Yes. There are many studies for this.  Have a look at the Difference study: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s3 You can create a study that does what you need. Refer to this page: http://www.sierrachart.com/index.php?l=doc/doc_CreatingDLLs.html We cannot provide any further help with this. Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
