Date/Time: Mon, 06 May 2024 05:24:28 +0000
[Locked] - Sierra Chart Configuration for Most Low Response Time Trading/Chart Updates
View Count: 4605
[2019-02-14 19:18:14] |
Refer to: Overview of Trading: Sierra Chart Configuration for Most Low Response Time Trading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-04-07 03:31:21] |
We amended the title to include chart updates. For charts and also Trading DOMs to update as fast as possible, you need to reduce the Chart >> Advanced Settings >> Chart Update Interval. We do not recommend going lower than 100 ms. And you need to have a good data feed. We recommend using the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed The data feed being used can make a difference with the updating of the chart and Trading DOM. You also need a good Internet connection as well. One thing about the Sierra Chart exchange data feed is that it is processed on a background thread. This is not the case when using CQG. And also will not be the case when using the new integration being worked on for Transact and also Rithmic. Those will be foreground processed. We do plan to bundle CME and EUREX data in with new upcoming packages. Although this is still months away. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-19 09:14:24
