Date/Time: Tue, 29 Sep 2026 17:02:57 +0000
Rows of Data dissappearing in depth on DOM -CQG data
View Count: 996
[2019-02-06 02:20:00]
User580737 - Posts: 8
Hi:
New user using CQG data plus FIX for routing
Two questions:
1. Data rows appearing on the ASK for the DOM are disappearing during the trading day. Eg. There are 20 data rows visible on the BID side - yet at times only 4 data rows appearing on the ASK side on the DOM - Have I set something up incorrectly?
2. Pre market I cannot see where the opening price is matching on the DOM for futures contracts - so I cannot see where the market is going to open. Can I configure something to see where the market is likely to open when in the pre-market phase on the DOM ?
Thank you
[2019-02-06 17:39:24]
1. No. Consider using the Sierra Chart Exchange Data Feed for data:
2. You can look at the best bid and ask prices which would be represented by colors based on the color settings, or by the Bid/Ask quantity numbers to see where the market is likely to open.
For the color settings, refer to:
Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM
You could also use a standard chart and enable this option on the chart:
Chart Menu: Show Bid and Ask Lines (Chart menu)
Date Time Of Last Edit: 2019-02-06 17:40:45
[2019-02-06 20:34:56]
Thanks - just in reply
1. The exchange I am having trouble with is the SFE (Sydney Futures Exchange) - it does not look like SierraCharts offer this exchange unfortunately ?
(I guess I can have multiple data source providers running in the one instance if need)
2. Perhaps oif I enable the the Best / Bid / Ask Background Box ?
I couldnt see a Best Bid and Ask Option - but i need to see where the price will open / match between the best bid and ask - not just asks well below the last price and bids well above
Thanks again
[2019-02-07 16:43:32]
1. No it is not offered. We cannot help with any CQG market data issues.
2. Yes you can use that color setting.
Date Time Of Last Edit: 2019-02-07 16:43:56
[2019-02-07 20:20:58]
The issue of losing data rows on the offer side of the DOM only affects the SFE data.
CME is not affected
If I have to use an alternative data supply to remedy - I'm happy to do so if it is a CQG / Sierra combination issue for SFE
But if there is no alternative to SFE data than CQG I'm stuck
I still need CQG for routing
I have contacted CQG they simply say they can see indefinite rows of SFE data in their DOM so their data is OK - doesn't help me.
I'm also using CQG for three other futures exchanges.
Changing color palettes on DOM didn't allow me to see where the market would open for SFE - I'll keep fiddling but open suggestions
