Date/Time: Fri, 24 Jan 2025 19:52:14 +0000
tool config box
View Count: 651
[2019-01-31 19:24:08] |
User828417 - Posts: 32 |
Since the last update, double left clicking a chart drawing no longer brings up the chart drawing properties window (must right click and select from drop down). Is this intended?
[2019-01-31 19:50:47] |
This is supported but make sure you have enabled Global Settings >> Tool Settings >> Double Click on Drawing Brings Up Drawing Properties and Support Left Click to Select Chart Drawings. However, we do see if you are using Support Drag for Chart Drawing Creation/Modification that you cannot do this. This is because this option interferes with the double-click. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-31 19:52:47
[2019-01-31 20:52:17] |
I have both these options selected and support drag is off. But since the last update, double clicking does not work.
[2019-01-31 21:02:23] |
We definitely do not observe any problem with a double-click opening the Chart Drawing properties window for the drawing clicked on. First thing we want you to do is to attach that chart following these instructions here: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-31 21:02:41
