Date/Time: Tue, 04 Nov 2025 16:32:28 +0000
Studies Template as Analysis
View Count: 1405
[2019-01-25 10:42:16]
User590016 - Posts: 50
I've configured different studies individually and saved them as a template to apply them whenever I need them.
I have around 10 differents studies on the "analysis" tab available.
Why can't I add like 5 off them onto the chart? Based on the the documentation I can only add 2 studies.
Isn't there a way to simple check all the studies you wish to add onto the chart?
[2019-01-26 05:09:34]
You can add as many of the Study Collections as you need to the chart. We do not know where you found the statement that only 2 can be added at a time.
The one thing to be aware of is that when you save the Study Collection, you need to select the box on the Chart Studies window that states Prompt to Remove Existing Studies. Refer to the following documentation for this:
Study Collections: Adding a Study Collection Without Clearing Existing Studies On The Chart (Prompt to Remove Existing Studies)
[2021-06-20 01:40:39]
User628616 - Posts: 132
How do I delete my saved template studies that I no longer use and want to remove from the Analysis drop down menu
[2021-06-20 02:51:27]
Refer to:
Study Collections: Delete a Study Collection
