Date/Time: Fri, 24 Jan 2025 14:53:11 +0000
Renko Chart / Ray Lines, Parallel Lines Misplaced
View Count: 763
[2019-01-24 11:33:43] |
User371906 - Posts: 141 |
Hello, When I draw a trend line in this case on a Renko 10-6-0 and have Copy Chart Drawing to my other Renko 34-18-0 it misplaces the line by a good difference and out of the market structure completely. Many of my drawn channels, ray lines, crosshair, etc. are misplaced from a low time frame to a higher time frame and vice versa. I this normal for Renko charts to be drawn like this or I there anything I can do settings wise to correct this? Renko 10-6-0 http://www.sierrachart.com/image.php?Image=1548328887524.png Renko 34-18-0 http://www.sierrachart.com/image.php?Image=1548328843647.png Thank you Date Time Of Last Edit: 2019-01-24 11:43:04
[2019-01-24 21:44:37] |
This could very well be normal because those are variable timeframe bars. Assuming the drawing in the destination is actually a copied drawing and there is no problem with the timestamps.
