Date/Time: Fri, 24 Jan 2025 13:13:35 +0000
[Locked] - Sierrachart showing error when placing and then cancelling order on IB
View Count: 1234
[2019-01-23 17:56:24]
rc7rader - Posts: 144
I clean installed Windows 10 and reinstalled all my applications including IB TWS and Sierrachart. In reinstalling Sierrachart, I copied the Sierrachart folders I backed up to drive D where the old Sierrachart used to be and reinstalled Sierrachart on the folder. Also, I used to run Sierrachart version 1689 and now I have version 1865.
I don't know what changed because I do not get an error before but now when I tried placing an order using Sierrachart and then decided to cancel the order, the error log comes out with the following messages:
Trade Activity Log: File read result: 155 records inserted. 42 fill records inserted. 0 records filtered. | 2019-01-23 09:21:13
Trade Activity Log: File date-time limits: Sim records date-time limit is 2019-01-18 00:00:00. Non-sim records date-time limit is 2018-12-24 00:00:00. Non-sim fill record date-time limit is 2018-01-23 00:00:00. | 2019-01-23 09:21:13
Interactive Brokers | Requesting Open orders. | 2019-01-23 09:22:29
Interactive Brokers | Requesting historical order fills for account U672*. Starting date: 20190109-00:00:00 | 2019-01-23 09:22:29
Interactive Brokers | Received position. Trade Account: U67254. Symbol: EUR.USD-CASH-IDEALPRO | 2019-01-23 09:22:29
Interactive Brokers | Received Open orders end message. | 2019-01-23 09:22:29
Trading message from IB: Order Event Warning:Attribute 'Outside Regular Trading Hours' is ignored based on the order type and destination. PlaceOrder is now being processed. Error Code: 2109. ServiceOrderID: 3897. InternalOrderID: 10624. | 2019-01-23 09:43:52
Interactive Brokers | Requesting Open orders. | 2019-01-23 09:44:07
Interactive Brokers | Requesting historical order fills for account U672*. Starting date: 20190109-00:00:00 | 2019-01-23 09:44:07
Interactive Brokers | Received Open orders end message. | 2019-01-23 09:44:07
Trading message from IB: Order Canceled - reason:. Error Code: 202. ServiceOrderID: 3896. InternalOrderID: 10623. | 2019-01-23 09:44:32
Trading message from IB: Order Canceled - reason:. Error Code: 202. ServiceOrderID: 3897. InternalOrderID: 10624. | 2019-01-23 09:44:32
Trading message from IB: Order Canceled - reason:. Error Code: 202. ServiceOrderID: 3898. InternalOrderID: 10625. | 2019-01-23 09:44:32
Trading message from IB: Order rejected - reason:No such order. Error Code: 201. ServiceOrderID: 3897. InternalOrderID: 10624. | 2019-01-23 09:44:32 *
Trading message from IB: Order rejected - reason:No such order. Error Code: 201. ServiceOrderID: 3898. InternalOrderID: 10625. | 2019-01-23 09:44:32 *
Interactive Brokers | Requesting Open orders. | 2019-01-23 09:44:47
Interactive Brokers | Received Open orders end message. | 2019-01-23 09:44:47
Trading message from IB: Order Event Warning:Attribute 'Outside Regular Trading Hours' is ignored based on the order type and destination. PlaceOrder is now being processed. Error Code: 2109. ServiceOrderID: 3900. InternalOrderID: 10627. | 2019-01-23 09:46:51
Trading message from IB: Order Canceled - reason:. Error Code: 202. ServiceOrderID: 3899. InternalOrderID: 10626. | 2019-01-23 09:46:55
Trading message from IB: Order Canceled - reason:. Error Code: 202. ServiceOrderID: 3900. InternalOrderID: 10627. | 2019-01-23 09:46:55
Trading message from IB: Order Canceled - reason:. Error Code: 202. ServiceOrderID: 3901. InternalOrderID: 10628. | 2019-01-23 09:46:55
Trading message from IB: Order rejected - reason:No such order. Error Code: 201. ServiceOrderID: 3900. InternalOrderID: 10627. | 2019-01-23 09:46:55 *
Trading message from IB: Order rejected - reason:No such order. Error Code: 201. ServiceOrderID: 3901. InternalOrderID: 10628. | 2019-01-23 09:46:55 *
Interactive Brokers | Requesting Open orders. | 2019-01-23 09:47:10
Interactive Brokers | Received Open orders end message. | 2019-01-23 09:47:10
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 10:00:00 | 2019-01-23 10:19:14
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 10:00:00 | 2019-01-23 10:19:27
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 10:00:00 | 2019-01-23 10:19:28
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 10:00:00 | 2019-01-23 10:19:42
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 10:00:00 | 2019-01-23 10:20:01
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 10:00:00 | 2019-01-23 10:20:15
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 10:00:00 | 2019-01-23 10:20:16
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 10:00:00 | 2019-01-23 10:20:18
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 10:00:00 | 2019-01-23 10:20:22
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 10:00:00 | 2019-01-23 10:21:01
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 10:00:00 | 2019-01-23 10:21:04
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 10:00:00 | 2019-01-23 10:21:06
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 10:00:00 | 2019-01-23 10:21:14
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 10:00:00 | 2019-01-23 10:21:24
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 10:00:00 | 2019-01-23 10:23:36
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 10:00:00 | 2019-01-23 10:23:56
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 11:30:00 | 2019-01-23 12:26:35
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 11:30:00 | 2019-01-23 12:27:01
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 11:30:00 | 2019-01-23 12:27:03
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 11:30:00 | 2019-01-23 12:27:07
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 11:30:00 | 2019-01-23 12:27:18
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 11:30:00 | 2019-01-23 12:27:21
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 11:30:00 | 2019-01-23 12:27:24
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 11:30:00 | 2019-01-23 12:27:27
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 11:30:00 | 2019-01-23 12:27:39
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 11:30:00 | 2019-01-23 12:27:48
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 11:30:00 | 2019-01-23 12:27:53
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 11:30:00 | 2019-01-23 12:27:57
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 11:30:00 | 2019-01-23 12:28:26
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 11:30:00 | 2019-01-23 12:28:34
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 11:30:00 | 2019-01-23 12:29:32
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 11:30:00 | 2019-01-23 12:29:47
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 11:30:00 | 2019-01-23 12:29:50
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 11:30:00 | 2019-01-23 12:29:53
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 11:30:00 | 2019-01-23 12:29:56
Heavy Vol >5min | Signal ignored because 'Signal Only Once Per Bar' is enabled and a signal was already given from formula column for bar. | Cell: P3 | Bar start date-time: 2019-01-23 11:30:00 | 2019-01-23 12:29:59
Interactive Brokers | Received position. Trade Account: U67254. Symbol: EUR.USD-CASH-IDEALPRO | 2019-01-23 12:31:50
Trading message from IB: Order Event Warning:Attribute 'Outside Regular Trading Hours' is ignored based on the order type and destination. PlaceOrder is now being processed. Error Code: 2109. ServiceOrderID: 3903. InternalOrderID: 10630. | 2019-01-23 12:37:05
Trading message from IB: Order Canceled - reason:. Error Code: 202. ServiceOrderID: 3902. InternalOrderID: 10629. | 2019-01-23 12:37:12
Trading message from IB: Order Canceled - reason:. Error Code: 202. ServiceOrderID: 3903. InternalOrderID: 10630. | 2019-01-23 12:37:12
Trading message from IB: Order Canceled - reason:. Error Code: 202. ServiceOrderID: 3904. InternalOrderID: 10631. | 2019-01-23 12:37:12
Trading message from IB: Order rejected - reason:No such order. Error Code: 201. ServiceOrderID: 3903. InternalOrderID: 10630. | 2019-01-23 12:37:12 *
Trading message from IB: Order rejected - reason:No such order. Error Code: 201. ServiceOrderID: 3904. InternalOrderID: 10631. | 2019-01-23 12:37:13 *
Interactive Brokers | Requesting Open orders. | 2019-01-23 12:37:27
Interactive Brokers | Received Open orders end message. | 2019-01-23 12:37:27
Trading message from IB: Order Event Warning:Attribute 'Outside Regular Trading Hours' is ignored based on the order type and destination. PlaceOrder is now being processed. Error Code: 2109. ServiceOrderID: 3906. InternalOrderID: 10633. | 2019-01-23 12:38:32
Trading message from IB: Order Canceled - reason:. Error Code: 202. ServiceOrderID: 3905. InternalOrderID: 10632. | 2019-01-23 12:38:39
Trading message from IB: Order Canceled - reason:. Error Code: 202. ServiceOrderID: 3906. InternalOrderID: 10633. | 2019-01-23 12:38:39
Trading message from IB: Order Canceled - reason:. Error Code: 202. ServiceOrderID: 3907. InternalOrderID: 10634. | 2019-01-23 12:38:39
Trading message from IB: Order rejected - reason:No such order. Error Code: 201. ServiceOrderID: 3906. InternalOrderID: 10633. | 2019-01-23 12:38:39 *
Trading message from IB: Order rejected - reason:No such order. Error Code: 201. ServiceOrderID: 3907. InternalOrderID: 10634. | 2019-01-23 12:38:39 *
Interactive Brokers | Requesting Open orders. | 2019-01-23 12:38:54
Interactive Brokers | Received Open orders end message. | 2019-01-23 12:38:54
The order is cancelled on IB TWS but why is Sierrachart showing these errors? Is there anything I have to reconfigure on Sierrachart or IB?
Thanks.
[2019-01-23 23:13:46]
You need to ask Interactive Brokers why they are sending errors like this one:
We do not know.
The basic fact is, is that the TWS API error reporting is an absolute utter mess. It is unreliable and messy from the TWS side.
We do not want to hear further about this. This trash is for Interactive Brokers to solve. Not us.
Reaffirming, that interactive brokers handling of orders is a complete mess and this is complete utter trash for them to have a common error reporting function for errors of any type including market data and trading.
Date Time Of Last Edit: 2019-01-28 04:26:23
