Date/Time: Sun, 05 May 2024 15:08:53 +0000
How can hide account number in Chart Trade Window
View Count: 2171
[2019-01-22 11:30:27] |
Marc@SC - Posts: 13 |
Hi, how can I hide the account number in the Trade Chart Window or can setup an alias? Thanks |
[2019-02-01 13:55:52] |
kremat0r - Posts: 41 |
H, need the same. Sometimes I'm making videos, so it's good to hide partially account number to have it like this Account: A9987654321 After: A998******* Thanks |
[2019-02-01 17:24:35] |
This is not supported but we will see about this capability.
[2019-02-05 19:55:05] |
Thanks, I appreciate.
[2019-10-09 15:11:16] |
Is there anything new about the implementation of this feature (hide partially account number in Chart Window and Trade Activity Log)? Thanks |
[2020-01-21 04:22:00] |
joshtrader - Posts: 439 |
Hi SC, I would like to request this -- I am recording my videos now and while I tend to be the primary viewer, if I show to someone else it would be almost impossible to edit the videos with the windows moving around to hide the number. A simple mask like 12**** for 123456 would suffice I think. Please consider, and thank you.
[2020-11-28 20:23:06] |
RIFT - Posts: 124 |
Is there anything new about this?
[2020-12-09 18:06:13] |
User90125 - Posts: 715 |
+1
[2020-12-09 21:49:00] |
Ackin - Posts: 1865 |
+ 1 |
[2020-12-09 22:47:44] |
User48838 - Posts: 112 |
+1
[2020-12-11 09:00:48] |
So you are looking to have the trade account identifier displayed on the Trade Window hidden? We have to think about how to go about that. There are a lot of complications with this and it probably will trigger numerous problems when we try to make this work. This is exactly what we want to avoid. So we do not have much interest in trying to accomplish this. As soon as we do this, then we start getting all of these complaints on the board about all kinds of unexpected problems. So tentatively we are not going to do this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-11 09:01:30
[2020-12-11 11:07:55] |
I don't want to upset you, but I have one last suggestion for this: Add "Color of Trading account Text" for this item only - everyone could give the color of the account text the same as the background and it would not be visible. It can not cause any problems (meant:technical problems on your side ....) Date Time Of Last Edit: 2020-12-11 13:49:04
[2020-12-12 16:49:55] |
@TRADE_YOUR_PLAN - Posts: 126 |
Brilliant solution, Ackin. Would appreciate this greatly as well. Edit below: @ Sierra Chart Support: Just to clarify, I think Ackin's proposed solution would be adding a color setting in: Graphic Settings - Global > Chart Trade Window Account Number Text Color Date Time Of Last Edit: 2020-12-12 16:55:14
[2020-12-15 19:19:25] |
In the next release, there will be a setting, on the Trade Window menu, to completely hide the Trade Account list altogether. That is the most simplified way to do this and not cause any unexpected side effects.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-15 19:19:58
[2020-12-16 21:22:03] |
I'm using prerelease 2210 and I see the menu option, but after selecting "Hide Trade Account List" nothing happens. Is it implemented yet? Thanks
[2020-12-17 03:11:01] |
We did not implement it on the Compact (C) Trade Window tab yet. Are you looking at the compact tab of the Trade window or the main trade window tab?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-17 03:11:21
[2020-12-17 04:00:50] |
I am viewing it on the compact window (detached). I've got to use the detached because of the blinking attached trade window. For that blinking issue, Sierra Chart Engineering said that windows is absolute garbage and probably the cause of the blinking every second or so. Anyways, noted on compact not being affected by the new setting. Would definitely appreciate it working for compact as well as it saves space. Thanks! |
[2020-12-17 05:45:02] |
We will work on hiding it for the compact tab. Sierra Chart Engineering said that windows is absolute garbage and probably the cause of the blinking every second or so. Yes we do remember this, and it is our plan to replace the garbage Trade Window, with a fully new implementation and we hope to get to that within the next three months.
