Date/Time: Wed, 08 May 2024 00:57:25 +0000
Please Consider Adding Join Bid and Join Ask Trade Buttons
View Count: 948
[2019-01-20 19:17:18] |
cmet - Posts: 538 |
These are basic one click Limit Order buttons that would add you to the inside bid or ask along with your attached orders. Perhaps they can be listed under Chart Trade Settings > Trade Window Control where they could be Displayed/Hidden. |
join bid-ask.jpg / V - Attached On 2019-01-20 19:17:07 UTC - Size: 23.07 KB - 306 views |
[2019-01-21 05:26:05] |
How is this different than Buy Bid and Sell Ask?
[2019-01-21 16:15:31] |
cmet - Posts: 538 |
You're right, it's not. In the 10 or so execution platforms I've used over the past 15 years, I've just never seen it called that. Thanks for pointing that out. Date Time Of Last Edit: 2019-01-21 16:15:45
