Date/Time: Tue, 04 Nov 2025 14:59:35 +0000
SC 961
View Count: 2873
|   [2013-04-09 03:20:30]     |
| TechTrader - Posts: 116 |
                The Study 'Color Background Based On Alert Condition' Settings> 'Use Vertical Line instead of Coloring Background'> 'No' does not color the background but remains as 'Yes' option. SC959 worked as stated. |
|   [2013-04-09 03:44:16]     |
                This will be corrected in the next release.
                 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2013-04-09 23:23:24]     |
                SC 962 Color Background Based On Alert Condition issue remains. Also the chart scaling cannot scale to round numbers. Downgraded back to SC959.  |
|   [2013-04-10 00:12:00]     |
                There has been changes to scaling.  We are not scaling to round numbers because that is really a technically difficult thing to always reliably resolve in the case of studies. In regards to what you are describing with Color Background Based On Alert Condition, just change the Width of the first Study Subgraph to 1. We also see a continued problem and it will be resolved in the next release. However, just do what we said for now. Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-10 00:34:22
|   [2013-04-10 00:33:57]     |
                We made another change to the scaling to round off to the nearest multiple are some multiple of 1. This will be out in the next release.
|   [2013-04-10 05:28:29]     |
                Both of these are now resolved in 962.
                 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-10 05:28:40
