Date/Time: Mon, 06 May 2024 15:26:44 +0000
CME Two-Year Note Futures (ZT) Updating Instructions
View Count: 1268
[2019-01-15 08:46:58] |
Due to a tick size change by the CME for the ZT futures, it is necessary to follow these instructions if you are charting or trading this market in Sierra Chart: 1. Update to prerelease 1861: Software Download: Fast Update 2. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings This should happen automatically on an update of Sierra Chart. So there usually is not a need to expressly do this. 3. Follow the instructions here for each chart or Trading DOM for ZT futures: Global Symbol Settings: Update/Apply Symbol Settings to Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
