Date/Time: Fri, 24 Jan 2025 00:33:21 +0000
ES rollover issue
View Count: 1226
[2018-12-17 12:08:07] |
AKR - Posts: 523 |
I have a daily chart that shows data from 12th Nov and next day it shows 13th of Dec. If I choose not to make a continous fut contract and just see EPH19 everything is fine. As soon I go to backadjustment etc it is like that. I have already deleted all ES.dly files via Edit/delete and also I just deleted them manually from the data folder. I did "reload/recalculate", still same. Pls help. |
[2018-12-17 13:37:06] |
AKR - Posts: 523 |
thats kind of urgent. log file also says back adjustment for EPZ18 is zero, which can not be. I did delete the entire .dly and .scic files and still same issue. and even if I manually put in 4 to adjustment correction in the symbol settings it wont adjust for that 4. |
[2018-12-17 13:58:14] |
AKR - Posts: 523 |
Think I figured the issue. manual adjustment works, I misstyped symbol. log file says there is no data in dly files. but the thing is it looks for eg. file ESZ18.dly. That file exists, but is empty. The data is stored in file F.US.EPZ18.dly Date Time Of Last Edit: 2018-12-17 13:58:35
[2018-12-17 14:23:32] |
AKR - Posts: 523 |
ok, an other puzzle solved. had to change EP?## to F.US..... in historical in global symb settings. but now daily chart wont show more than half year or so? at least roll over works now. why the hell did that change? i never had to do that before? |
[2018-12-17 14:40:14] |
EP?## to F.US..... in historical in global symb settings. This does not make any sense whatsoever. You must have altered the symbol settings yourself. The Historical Chart symbol must ES?## for the CQG symbol F.US.EP?## and must not change.Why did you change this? Nobody ever has to alter these symbol settings directly. Also refer to: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-17 14:44:20
[2018-12-17 16:26:37] |
AKR - Posts: 523 |
I changed now back to ES?##. When I reload recalculate the daily chart I only see 3 days (of h19 contract). and I have set to continuous contract. what can I say. ... I have in my data folder files called ES?##.dly and I have files called F.US.EP?##. First ones are empty. That seems to be the issue for me. |
[2018-12-17 16:33:31] |
Just follow through the instructions here: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data There might be a historical data download issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-17 16:33:33] |
[2018-12-17 16:50:36] |
AKR - Posts: 523 |
I ve done all that several times before. i even did delete all files in the data folder.... look below. it wants to get the prices from dly file to have data for adjustment. but it does not find anything. because the ES?## files are empty. the data is in the F.US.EP?## files F.US.EPH19 [CB] Daily #14 | Error while getting daily open price with date 2017-09-10 from file. C:\SierraChart\Data\ESU17.dly. Error: No Data for read. End of file. | 2018-12-17 17:48:08 F.US.EPH19 [CB] Daily #14 | Error while getting daily open price with date 2017-09-10 from file. C:\SierraChart\Data\ESZ17.dly. Error: No Data for read. End of file. | 2018-12-17 17:48:08 F.US.EPH19 [CB] Daily #14 | F.US.EPU17 price difference to F.US.EPZ17 is 0. | 2018-12-17 17:48:08 F.US.EPH19 [CB] Daily #14 | Error while getting daily open price with date 2017-12-10 from file. C:\SierraChart\Data\ESZ17.dly. Error: No Data for read. End of file. | 2018-12-17 17:48:08 F.US.EPH19 [CB] Daily #14 | Error while getting daily open price with date 2017-12-10 from file. C:\SierraChart\Data\ESH18.dly. Error: No Data for read. End of file. | 2018-12-17 17:48:08 F.US.EPH19 [CB] Daily #14 | F.US.EPZ17 price difference to F.US.EPH18 is 0. | 2018-12-17 17:48:08 F.US.EPH19 [CB] Daily #14 | Error while getting daily open price with date 2018-03-11 from file. C:\SierraChart\Data\ESH18.dly. Error: No Data for read. End of file. | 2018-12-17 17:48:08 F.US.EPH19 [CB] Daily #14 | Error while getting daily open price with date 2018-03-11 from file. C:\SierraChart\Data\ESM18.dly. Error: No Data for read. End of file. | 2018-12-17 17:48:08 F.US.EPH19 [CB] Daily #14 | Adjusting price difference from 0 by user specified amount of -1 to -1 | 2018-12-17 17:48:08 F.US.EPH19 [CB] Daily #14 | F.US.EPH18 price difference to F.US.EPM18 is -1. | 2018-12-17 17:48:08 F.US.EPH19 [CB] Daily #14 | Error while getting daily open price with date 2018-06-10 from file. C:\SierraChart\Data\ESM18.dly. Error: No Data for read. End of file. | 2018-12-17 17:48:08 F.US.EPH19 [CB] Daily #14 | Error while getting daily open price with date 2018-06-10 from file. C:\SierraChart\Data\ESU18.dly. Error: No Data for read. End of file. | 2018-12-17 17:48:08 F.US.EPH19 [CB] Daily #14 | Adjusting price difference from 0 by user specified amount of -0.5 to -0.5 | 2018-12-17 17:48:08 F.US.EPH19 [CB] Daily #14 | F.US.EPM18 price difference to F.US.EPU18 is -0.5. | 2018-12-17 17:48:08 F.US.EPH19 [CB] Daily #14 | Error while getting daily open price with date 2018-09-16 from file. C:\SierraChart\Data\ESU18.dly. Error: No Data for read. End of file. | 2018-12-17 17:48:08 F.US.EPH19 [CB] Daily #14 | Error while getting daily open price with date 2018-09-16 from file. C:\SierraChart\Data\ESZ18.dly. Error: No Data for read. End of file. | 2018-12-17 17:48:08 F.US.EPH19 [CB] Daily #14 | Adjusting price difference from 0 by user specified amount of -0.5 to -0.5 | 2018-12-17 17:48:08 F.US.EPH19 [CB] Daily #14 | F.US.EPU18 price difference to F.US.EPZ18 is -0.5. | 2018-12-17 17:48:08 F.US.EPH19 [CB] Daily #14 | Error while getting daily open price with date 2018-12-16 from file. C:\SierraChart\Data\ESZ18.dly. Error: No Data for read. End of file. | 2018-12-17 17:48:08 F.US.EPH19 [CB] Daily #14 | F.US.EPH19 Open price on 2018-12-13 is 2657.25. | 2018-12-17 17:48:08 F.US.EPH19 [CB] Daily #14 | Adjusting price difference from 0 by user specified amount of -0.25 to -0.25 | 2018-12-17 17:48:08 |
[2018-12-17 19:12:50] |
AKR - Posts: 523 |
I did now once more delete all files and start sierra new, waiting for download of data. still same issue. I would highly appreciate if you could long on to my PC to check it. I dont know what to do. THANK YOU !!!! |
[2018-12-18 11:50:20] |
AKR - Posts: 523 |
Any answer to this? Guys, I make a living of trading, I am depending on your SW. I have no clue what happend. I had not turned on my PC for a week, coming back turning on and rollover not working. I did not change anything in between ... |
[2018-12-18 12:06:48] |
AKR - Posts: 523 |
look at window of delete all data and download. why is the actual contract shown as F.US etc. and the rest of the contracts not? this is DAX, also not working. Checked for other symbols, all not working. |
delete download.JPG / V - Attached On 2018-12-18 12:06:38 UTC - Size: 30 KB - 285 views |
[2018-12-18 12:14:58] |
AKR - Posts: 523 |
very strange. what I did now is not to select "all contracts" but only all 3 first. then it did download data and shows them in chart. then I selected the rest but not first 3 and it did download. I have NO CLUE why this now is working. Ok, now did with other symbol and did not make the 3 only, but selected all. and now it worked. I have no clue why. probably it was up to borker???? CQG? no idea. anyway, problem seems solved, very strange though. |
[2018-12-18 12:20:20] |
AKR - Posts: 523 |
sorry again me. so now there is data in the .dly files. only in actual contract not, but for actual contract it is in F.US.EP... and therefore it can not make the backadjustment for Dec contract. How do I tell the software it should save in the ES?##.dly file? sorry for being anoying, but dont see as my fault. |
[2018-12-18 12:41:16] |
AKR - Posts: 523 |
so I did now rename the F.US.EP file to ES?## file. Now at least in makes the backadjustment as it finds the file but the new daily data is still saved to F.US.EPH19 file... is that how it should be?
[2018-12-18 18:11:59] |
Do not do any file renames. That is totally unnecessary and is only further creating a problem. The file names and symbols are correct as you see them. ----- Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Fully re-download the data in the chart by going to the chart and selecting "Edit >>Delete All Data and Download". In this case you will want to select all the symbols. After about a minute provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Just do this and do not write anything further and we will see what the issue is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-18 18:12:11
[2018-12-19 07:43:01] |
AKR - Posts: 523 |
no everything looks normal. I also deleted all .dly files before. now it also does the backadjustment of 4.25 for Dec. Looks I m stupid, but the issues where there. Software version: 1850 64-bit | 2018-12-19 08:38:24 Usage end date: 2019-06-12 | 2018-12-19 08:38:24 Enabled for: Advanced Features. | 2018-12-19 08:38:24 Enabled for: Advanced Features 2. | 2018-12-19 08:38:24 Enabled for: Sierra Chart Historical Data Service. | 2018-12-19 08:38:24 Allow Support for Sierra Chart Data Feeds is disabled. | 2018-12-19 08:38:24 Current selected Data/Trading service: CQG FIX Trading | 2018-12-19 08:38:24 Chart Update Interval: 50 | 2018-12-19 08:38:24 Time Zone: +01:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2018-12-19 08:38:24 2018-12-19 08:38:23 Local computer time | 2018-12-19 08:38:24 2018-12-19 07:38:23 Local computer time in UTC | 2018-12-19 08:38:24 2018-12-19 08:38:23 Local computer time in SC Time Zone | 2018-12-19 08:38:24 2018-12-19 07:30:39 Server time in UTC | 2018-12-19 08:38:24 Local computer UTC time and Server UTC time difference: 6 seconds. | 2018-12-19 08:38:24 Program path: C:\SierraChart\ | 2018-12-19 08:38:24 Data Files path: C:\SierraChart\Data\ | 2018-12-19 08:38:24 OS Version Number: 6.1 | 2018-12-19 08:38:24 Locale Setting: C | 2018-12-19 08:38:24 DLLs: Convergent_64(2).dll, Convergent_64.dll, Line to last.dll, Line to last_64.dll, relVolume(OT).dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2018-12-19 08:38:24 HD Request # 121 | Downloading Historical Daily chart data for ESZ10. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:38:28 HD Request # 121 | Requesting historical Daily data for ESZ10 starting at 1968-12-17 | 2018-12-19 08:38:28 HD Request # 121 | Receiving historical Daily data for ESZ10 starting at 2009-09-18 | 2018-12-19 08:38:30 HD Request # 121 | Writing historical Daily data to the file ESZ10.dly | 2018-12-19 08:38:30 HD Request # 121 | Received 317 records from 2009-09-18 00:00:00 to 2010-12-17 00:00:00 (456.0 days) and wrote 317 records for ESZ10 | 2018-12-19 08:38:30 HD Request # 121 | Completion time: 0s | 2018-12-19 08:38:30 HD Request # 121 | Daily data download complete for ESZ10. Unique request ID: 119 | 2018-12-19 08:38:30 Removed historical data download ID 119 | 2018-12-19 08:38:30 HD Request # 122 | Downloading Historical Daily chart data for ESH11. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:38:30 HD Request # 122 | Requesting historical Daily data for ESH11 starting at 1968-12-17 | 2018-12-19 08:38:30 HD Request # 122 | Receiving historical Daily data for ESH11 starting at 2009-12-02 | 2018-12-19 08:38:31 HD Request # 122 | Writing historical Daily data to the file ESH11.dly | 2018-12-19 08:38:31 HD Request # 122 | Received 316 records from 2009-12-02 00:00:00 to 2011-03-18 00:00:00 (472.0 days) and wrote 316 records for ESH11 | 2018-12-19 08:38:31 HD Request # 122 | Completion time: 2s | 2018-12-19 08:38:31 HD Request # 122 | Daily data download complete for ESH11. Unique request ID: 120 | 2018-12-19 08:38:31 Removed historical data download ID 120 | 2018-12-19 08:38:31 HD Request # 123 | Downloading Historical Daily chart data for ESM11. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:38:31 HD Request # 123 | Requesting historical Daily data for ESM11 starting at 1968-12-17 | 2018-12-19 08:38:31 HD Request # 123 | Receiving historical Daily data for ESM11 starting at 2010-03-19 | 2018-12-19 08:38:33 HD Request # 123 | Writing historical Daily data to the file ESM11.dly | 2018-12-19 08:38:33 HD Request # 123 | Received 317 records from 2010-03-19 00:00:00 to 2011-06-17 00:00:00 (456.0 days) and wrote 317 records for ESM11 | 2018-12-19 08:38:33 HD Request # 123 | Completion time: 1s | 2018-12-19 08:38:33 HD Request # 123 | Daily data download complete for ESM11. Unique request ID: 121 | 2018-12-19 08:38:33 Removed historical data download ID 121 | 2018-12-19 08:38:33 HD Request # 124 | Downloading Historical Daily chart data for ESU11. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:38:33 HD Request # 124 | Requesting historical Daily data for ESU11 starting at 1968-12-17 | 2018-12-19 08:38:33 HD Request # 124 | Receiving historical Daily data for ESU11 starting at 2010-06-18 | 2018-12-19 08:38:34 HD Request # 124 | Writing historical Daily data to the file ESU11.dly | 2018-12-19 08:38:34 HD Request # 124 | Received 316 records from 2010-06-18 00:00:00 to 2011-09-16 00:00:00 (456.0 days) and wrote 316 records for ESU11 | 2018-12-19 08:38:34 HD Request # 124 | Completion time: 2s | 2018-12-19 08:38:34 HD Request # 124 | Daily data download complete for ESU11. Unique request ID: 122 | 2018-12-19 08:38:34 Removed historical data download ID 122 | 2018-12-19 08:38:34 HD Request # 125 | Downloading Historical Daily chart data for ESZ11. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:38:34 HD Request # 125 | Requesting historical Daily data for ESZ11 starting at 1968-12-17 | 2018-12-19 08:38:34 HD Request # 125 | Receiving historical Daily data for ESZ11 starting at 2010-09-17 | 2018-12-19 08:38:36 HD Request # 125 | Writing historical Daily data to the file ESZ11.dly | 2018-12-19 08:38:36 HD Request # 125 | Received 317 records from 2010-09-17 00:00:00 to 2011-12-16 00:00:00 (456.0 days) and wrote 317 records for ESZ11 | 2018-12-19 08:38:36 HD Request # 125 | Completion time: 1s | 2018-12-19 08:38:36 HD Request # 125 | Daily data download complete for ESZ11. Unique request ID: 123 | 2018-12-19 08:38:36 Removed historical data download ID 123 | 2018-12-19 08:38:36 HD Request # 126 | Downloading Historical Daily chart data for ESH12. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:38:36 HD Request # 126 | Requesting historical Daily data for ESH12 starting at 1968-12-17 | 2018-12-19 08:38:36 HD Request # 126 | Receiving historical Daily data for ESH12 starting at 2010-12-17 | 2018-12-19 08:38:37 HD Request # 126 | Writing historical Daily data to the file ESH12.dly | 2018-12-19 08:38:37 HD Request # 126 | Received 314 records from 2010-12-17 00:00:00 to 2012-03-16 00:00:00 (456.0 days) and wrote 314 records for ESH12 | 2018-12-19 08:38:37 HD Request # 126 | Completion time: 2s | 2018-12-19 08:38:37 HD Request # 126 | Daily data download complete for ESH12. Unique request ID: 124 | 2018-12-19 08:38:37 Removed historical data download ID 124 | 2018-12-19 08:38:37 HD Request # 127 | Downloading Historical Daily chart data for ESM12. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:38:37 HD Request # 127 | Requesting historical Daily data for ESM12 starting at 1968-12-17 | 2018-12-19 08:38:37 HD Request # 127 | Receiving historical Daily data for ESM12 starting at 2011-03-18 | 2018-12-19 08:38:39 HD Request # 127 | Writing historical Daily data to the file ESM12.dly | 2018-12-19 08:38:39 HD Request # 127 | Received 316 records from 2011-03-18 00:00:00 to 2012-06-15 00:00:00 (456.0 days) and wrote 316 records for ESM12 | 2018-12-19 08:38:39 HD Request # 127 | Completion time: 1s | 2018-12-19 08:38:39 HD Request # 127 | Daily data download complete for ESM12. Unique request ID: 125 | 2018-12-19 08:38:39 Removed historical data download ID 125 | 2018-12-19 08:38:39 HD Request # 128 | Downloading Historical Daily chart data for ESU12. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:38:39 HD Request # 128 | Requesting historical Daily data for ESU12 starting at 1968-12-17 | 2018-12-19 08:38:39 HD Request # 128 | Receiving historical Daily data for ESU12 starting at 2011-06-17 | 2018-12-19 08:38:41 HD Request # 128 | Writing historical Daily data to the file ESU12.dly | 2018-12-19 08:38:41 HD Request # 128 | Received 321 records from 2011-06-17 00:00:00 to 2012-09-21 00:00:00 (463.0 days) and wrote 321 records for ESU12 | 2018-12-19 08:38:41 HD Request # 128 | Completion time: 2s | 2018-12-19 08:38:41 HD Request # 128 | Daily data download complete for ESU12. Unique request ID: 126 | 2018-12-19 08:38:41 Removed historical data download ID 126 | 2018-12-19 08:38:41 HD Request # 129 | Downloading Historical Daily chart data for ESZ12. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:38:41 HD Request # 129 | Requesting historical Daily data for ESZ12 starting at 1968-12-17 | 2018-12-19 08:38:41 HD Request # 129 | Receiving historical Daily data for ESZ12 starting at 2011-09-06 | 2018-12-19 08:38:42 HD Request # 129 | Writing historical Daily data to the file ESZ12.dly | 2018-12-19 08:38:42 HD Request # 129 | Received 323 records from 2011-09-06 00:00:00 to 2012-12-21 00:00:00 (473.0 days) and wrote 323 records for ESZ12 | 2018-12-19 08:38:42 HD Request # 129 | Completion time: 2s | 2018-12-19 08:38:42 HD Request # 129 | Daily data download complete for ESZ12. Unique request ID: 127 | 2018-12-19 08:38:42 Removed historical data download ID 127 | 2018-12-19 08:38:42 HD Request # 130 | Downloading Historical Daily chart data for ESH13. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:38:42 HD Request # 130 | Requesting historical Daily data for ESH13 starting at 1968-12-17 | 2018-12-19 08:38:42 HD Request # 130 | Receiving historical Daily data for ESH13 starting at 2011-12-16 | 2018-12-19 08:38:44 HD Request # 130 | Writing historical Daily data to the file ESH13.dly | 2018-12-19 08:38:44 HD Request # 130 | Received 314 records from 2011-12-16 00:00:00 to 2013-03-15 00:00:00 (456.0 days) and wrote 314 records for ESH13 | 2018-12-19 08:38:44 HD Request # 130 | Completion time: 0s | 2018-12-19 08:38:44 HD Request # 130 | Daily data download complete for ESH13. Unique request ID: 128 | 2018-12-19 08:38:44 Removed historical data download ID 128 | 2018-12-19 08:38:44 HD Request # 131 | Downloading Historical Daily chart data for ESM13. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:38:44 HD Request # 131 | Requesting historical Daily data for ESM13 starting at 1968-12-17 | 2018-12-19 08:38:44 HD Request # 131 | Receiving historical Daily data for ESM13 starting at 2012-03-16 | 2018-12-19 08:38:45 HD Request # 131 | Writing historical Daily data to the file ESM13.dly | 2018-12-19 08:38:45 HD Request # 131 | Received 321 records from 2012-03-16 00:00:00 to 2013-06-21 00:00:00 (463.0 days) and wrote 321 records for ESM13 | 2018-12-19 08:38:45 HD Request # 131 | Completion time: 2s | 2018-12-19 08:38:45 HD Request # 131 | Daily data download complete for ESM13. Unique request ID: 129 | 2018-12-19 08:38:45 Removed historical data download ID 129 | 2018-12-19 08:38:45 HD Request # 132 | Downloading Historical Daily chart data for ESU13. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:38:45 HD Request # 132 | Requesting historical Daily data for ESU13 starting at 1968-12-17 | 2018-12-19 08:38:45 HD Request # 132 | Receiving historical Daily data for ESU13 starting at 2012-06-15 | 2018-12-19 08:38:47 HD Request # 132 | Writing historical Daily data to the file ESU13.dly | 2018-12-19 08:38:47 HD Request # 132 | Received 320 records from 2012-06-15 00:00:00 to 2013-09-20 00:00:00 (463.0 days) and wrote 320 records for ESU13 | 2018-12-19 08:38:47 HD Request # 132 | Completion time: 1s | 2018-12-19 08:38:47 HD Request # 132 | Daily data download complete for ESU13. Unique request ID: 130 | 2018-12-19 08:38:47 Removed historical data download ID 130 | 2018-12-19 08:38:47 HD Request # 133 | Downloading Historical Daily chart data for ESZ13. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:38:47 HD Request # 133 | Requesting historical Daily data for ESZ13 starting at 1968-12-17 | 2018-12-19 08:38:47 HD Request # 133 | Receiving historical Daily data for ESZ13 starting at 2012-09-21 | 2018-12-19 08:38:49 HD Request # 133 | Writing historical Daily data to the file ESZ13.dly | 2018-12-19 08:38:49 HD Request # 133 | Received 316 records from 2012-09-21 00:00:00 to 2013-12-20 00:00:00 (456.0 days) and wrote 316 records for ESZ13 | 2018-12-19 08:38:49 HD Request # 133 | Completion time: 2s | 2018-12-19 08:38:49 HD Request # 133 | Daily data download complete for ESZ13. Unique request ID: 131 | 2018-12-19 08:38:49 Removed historical data download ID 131 | 2018-12-19 08:38:49 HD Request # 134 | Downloading Historical Daily chart data for ESH14. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:38:49 HD Request # 134 | Requesting historical Daily data for ESH14 starting at 1968-12-17 | 2018-12-19 08:38:49 HD Request # 134 | Receiving historical Daily data for ESH14 starting at 2012-12-19 | 2018-12-19 08:38:50 HD Request # 134 | Writing historical Daily data to the file ESH14.dly | 2018-12-19 08:38:50 HD Request # 134 | Received 315 records from 2012-12-19 00:00:00 to 2014-03-21 00:00:00 (458.0 days) and wrote 315 records for ESH14 | 2018-12-19 08:38:50 HD Request # 134 | Completion time: 2s | 2018-12-19 08:38:50 HD Request # 134 | Daily data download complete for ESH14. Unique request ID: 132 | 2018-12-19 08:38:50 Removed historical data download ID 132 | 2018-12-19 08:38:50 HD Request # 135 | Downloading Historical Daily chart data for ESM14. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:38:50 HD Request # 135 | Requesting historical Daily data for ESM14 starting at 1968-12-17 | 2018-12-19 08:38:50 HD Request # 135 | Receiving historical Daily data for ESM14 starting at 2013-03-15 | 2018-12-19 08:38:52 HD Request # 135 | Writing historical Daily data to the file ESM14.dly | 2018-12-19 08:38:52 HD Request # 135 | Received 320 records from 2013-03-15 00:00:00 to 2014-06-20 00:00:00 (463.0 days) and wrote 320 records for ESM14 | 2018-12-19 08:38:52 HD Request # 135 | Completion time: 0s | 2018-12-19 08:38:52 HD Request # 135 | Daily data download complete for ESM14. Unique request ID: 133 | 2018-12-19 08:38:52 Removed historical data download ID 133 | 2018-12-19 08:38:52 HD Request # 136 | Downloading Historical Daily chart data for ESU14. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:38:52 HD Request # 136 | Requesting historical Daily data for ESU14 starting at 1968-12-17 | 2018-12-19 08:38:52 HD Request # 136 | Receiving historical Daily data for ESU14 starting at 2013-06-19 | 2018-12-19 08:38:53 HD Request # 136 | Writing historical Daily data to the file ESU14.dly | 2018-12-19 08:38:53 HD Request # 136 | Received 317 records from 2013-06-19 00:00:00 to 2014-09-19 00:00:00 (458.0 days) and wrote 317 records for ESU14 | 2018-12-19 08:38:53 HD Request # 136 | Completion time: 2s | 2018-12-19 08:38:53 HD Request # 136 | Daily data download complete for ESU14. Unique request ID: 134 | 2018-12-19 08:38:53 Removed historical data download ID 134 | 2018-12-19 08:38:53 HD Request # 137 | Downloading Historical Daily chart data for ESZ14. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:38:53 HD Request # 137 | Requesting historical Daily data for ESZ14 starting at 1968-12-17 | 2018-12-19 08:38:53 HD Request # 137 | Receiving historical Daily data for ESZ14 starting at 2013-09-18 | 2018-12-19 08:38:55 HD Request # 137 | Writing historical Daily data to the file ESZ14.dly | 2018-12-19 08:38:55 HD Request # 137 | Received 318 records from 2013-09-18 00:00:00 to 2014-12-19 00:00:00 (458.0 days) and wrote 318 records for ESZ14 | 2018-12-19 08:38:55 HD Request # 137 | Completion time: 0s | 2018-12-19 08:38:55 HD Request # 137 | Daily data download complete for ESZ14. Unique request ID: 135 | 2018-12-19 08:38:55 Removed historical data download ID 135 | 2018-12-19 08:38:55 HD Request # 138 | Downloading Historical Daily chart data for ESH15. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:38:55 HD Request # 138 | Requesting historical Daily data for ESH15 starting at 1968-12-17 | 2018-12-19 08:38:55 HD Request # 138 | Receiving historical Daily data for ESH15 starting at 2013-12-11 | 2018-12-19 08:38:56 HD Request # 138 | Writing historical Daily data to the file ESH15.dly | 2018-12-19 08:38:56 HD Request # 138 | Received 320 records from 2013-12-11 00:00:00 to 2015-03-20 00:00:00 (465.0 days) and wrote 320 records for ESH15 | 2018-12-19 08:38:56 HD Request # 138 | Completion time: 2s | 2018-12-19 08:38:56 HD Request # 138 | Daily data download complete for ESH15. Unique request ID: 136 | 2018-12-19 08:38:56 Removed historical data download ID 136 | 2018-12-19 08:38:56 HD Request # 139 | Downloading Historical Daily chart data for ESM15. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:38:56 HD Request # 139 | Requesting historical Daily data for ESM15 starting at 1968-12-17 | 2018-12-19 08:38:56 HD Request # 139 | Receiving historical Daily data for ESM15 starting at 2014-03-11 | 2018-12-19 08:38:58 HD Request # 139 | Writing historical Daily data to the file ESM15.dly | 2018-12-19 08:38:58 HD Request # 139 | Received 324 records from 2014-03-11 00:00:00 to 2015-06-19 00:00:00 (466.0 days) and wrote 324 records for ESM15 | 2018-12-19 08:38:58 HD Request # 139 | Completion time: 2s | 2018-12-19 08:38:58 HD Request # 139 | Daily data download complete for ESM15. Unique request ID: 137 | 2018-12-19 08:38:58 Removed historical data download ID 137 | 2018-12-19 08:38:58 HD Request # 140 | Downloading Historical Daily chart data for ESU15. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:38:58 HD Request # 140 | Requesting historical Daily data for ESU15 starting at 1968-12-17 | 2018-12-19 08:38:58 HD Request # 140 | Receiving historical Daily data for ESU15 starting at 2014-06-10 | 2018-12-19 08:38:59 HD Request # 140 | Writing historical Daily data to the file ESU15.dly | 2018-12-19 08:38:59 HD Request # 140 | Received 324 records from 2014-06-10 00:00:00 to 2015-09-18 00:00:00 (466.0 days) and wrote 324 records for ESU15 | 2018-12-19 08:38:59 HD Request # 140 | Completion time: 0s | 2018-12-19 08:38:59 HD Request # 140 | Daily data download complete for ESU15. Unique request ID: 138 | 2018-12-19 08:38:59 Removed historical data download ID 138 | 2018-12-19 08:38:59 HD Request # 141 | Downloading Historical Daily chart data for ESZ15. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:38:59 HD Request # 141 | Requesting historical Daily data for ESZ15 starting at 1968-12-17 | 2018-12-19 08:38:59 HD Request # 141 | Receiving historical Daily data for ESZ15 starting at 2014-09-10 | 2018-12-19 08:39:01 HD Request # 141 | Writing historical Daily data to the file ESZ15.dly | 2018-12-19 08:39:01 HD Request # 141 | Received 324 records from 2014-09-10 00:00:00 to 2015-12-18 00:00:00 (465.0 days) and wrote 324 records for ESZ15 | 2018-12-19 08:39:01 HD Request # 141 | Completion time: 2s | 2018-12-19 08:39:01 HD Request # 141 | Daily data download complete for ESZ15. Unique request ID: 139 | 2018-12-19 08:39:01 Removed historical data download ID 139 | 2018-12-19 08:39:01 HD Request # 142 | Downloading Historical Daily chart data for ESH16. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:39:01 HD Request # 142 | Requesting historical Daily data for ESH16 starting at 1968-12-17 | 2018-12-19 08:39:01 HD Request # 142 | Receiving historical Daily data for ESH16 starting at 2014-12-17 | 2018-12-19 08:39:03 HD Request # 142 | Writing historical Daily data to the file ESH16.dly | 2018-12-19 08:39:03 HD Request # 142 | Received 316 records from 2014-12-17 00:00:00 to 2016-03-18 00:00:00 (458.0 days) and wrote 316 records for ESH16 | 2018-12-19 08:39:03 HD Request # 142 | Completion time: 1s | 2018-12-19 08:39:03 HD Request # 142 | Daily data download complete for ESH16. Unique request ID: 140 | 2018-12-19 08:39:03 Removed historical data download ID 140 | 2018-12-19 08:39:03 HD Request # 143 | Downloading Historical Daily chart data for ESM16. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:39:03 HD Request # 143 | Requesting historical Daily data for ESM16 starting at 1968-12-17 | 2018-12-19 08:39:03 HD Request # 143 | Receiving historical Daily data for ESM16 starting at 2015-03-10 | 2018-12-19 08:39:05 HD Request # 143 | Writing historical Daily data to the file ESM16.dly | 2018-12-19 08:39:05 HD Request # 143 | Received 323 records from 2015-03-10 00:00:00 to 2016-06-17 00:00:00 (466.0 days) and wrote 323 records for ESM16 | 2018-12-19 08:39:05 HD Request # 143 | Completion time: 2s | 2018-12-19 08:39:05 HD Request # 143 | Daily data download complete for ESM16. Unique request ID: 141 | 2018-12-19 08:39:05 Removed historical data download ID 141 | 2018-12-19 08:39:05 HD Request # 144 | Downloading Historical Daily chart data for ESU16. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:39:05 HD Request # 144 | Requesting historical Daily data for ESU16 starting at 1968-12-17 | 2018-12-19 08:39:05 HD Request # 144 | Receiving historical Daily data for ESU16 starting at 2015-06-17 | 2018-12-19 08:39:06 HD Request # 144 | Writing historical Daily data to the file ESU16.dly | 2018-12-19 08:39:06 HD Request # 144 | Received 317 records from 2015-06-17 00:00:00 to 2016-09-16 00:00:00 (458.0 days) and wrote 317 records for ESU16 | 2018-12-19 08:39:06 HD Request # 144 | Completion time: 2s | 2018-12-19 08:39:06 HD Request # 144 | Daily data download complete for ESU16. Unique request ID: 142 | 2018-12-19 08:39:06 Removed historical data download ID 142 | 2018-12-19 08:39:06 HD Request # 145 | Downloading Historical Daily chart data for ESZ16. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:39:06 HD Request # 145 | Requesting historical Daily data for ESZ16 starting at 1968-12-17 | 2018-12-19 08:39:06 HD Request # 145 | Receiving historical Daily data for ESZ16 starting at 2015-09-18 | 2018-12-19 08:39:08 HD Request # 145 | Writing historical Daily data to the file ESZ16.dly | 2018-12-19 08:39:08 HD Request # 145 | Received 316 records from 2015-09-18 00:00:00 to 2016-12-16 00:00:00 (456.0 days) and wrote 316 records for ESZ16 | 2018-12-19 08:39:08 HD Request # 145 | Completion time: 1s | 2018-12-19 08:39:08 HD Request # 145 | Daily data download complete for ESZ16. Unique request ID: 143 | 2018-12-19 08:39:08 Removed historical data download ID 143 | 2018-12-19 08:39:08 HD Request # 146 | Downloading Historical Daily chart data for ESH17. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:39:08 HD Request # 146 | Requesting historical Daily data for ESH17 starting at 1968-12-17 | 2018-12-19 08:39:08 HD Request # 146 | Receiving historical Daily data for ESH17 starting at 2015-12-07 | 2018-12-19 08:39:09 HD Request # 146 | Writing historical Daily data to the file ESH17.dly | 2018-12-19 08:39:09 HD Request # 146 | Received 315 records from 2015-12-07 00:00:00 to 2017-03-17 00:00:00 (467.0 days) and wrote 315 records for ESH17 | 2018-12-19 08:39:09 HD Request # 146 | Completion time: 2s | 2018-12-19 08:39:09 HD Request # 146 | Daily data download complete for ESH17. Unique request ID: 144 | 2018-12-19 08:39:09 Removed historical data download ID 144 | 2018-12-19 08:39:09 HD Request # 147 | Downloading Historical Daily chart data for ESM17. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:39:09 HD Request # 147 | Requesting historical Daily data for ESM17 starting at 1968-12-17 | 2018-12-19 08:39:09 HD Request # 147 | Receiving historical Daily data for ESM17 starting at 2016-03-18 | 2018-12-19 08:39:11 HD Request # 147 | Writing historical Daily data to the file ESM17.dly | 2018-12-19 08:39:11 HD Request # 147 | Received 315 records from 2016-03-18 00:00:00 to 2017-06-16 00:00:00 (456.0 days) and wrote 315 records for ESM17 | 2018-12-19 08:39:11 HD Request # 147 | Completion time: 1s | 2018-12-19 08:39:11 HD Request # 147 | Daily data download complete for ESM17. Unique request ID: 145 | 2018-12-19 08:39:11 Removed historical data download ID 145 | 2018-12-19 08:39:11 HD Request # 148 | Downloading Historical Daily chart data for ESU17. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:39:11 HD Request # 148 | Requesting historical Daily data for ESU17 starting at 1968-12-17 | 2018-12-19 08:39:11 HD Request # 148 | Receiving historical Daily data for ESU17 starting at 2016-06-17 | 2018-12-19 08:39:12 HD Request # 148 | Writing historical Daily data to the file ESU17.dly | 2018-12-19 08:39:12 HD Request # 148 | Received 315 records from 2016-06-17 00:00:00 to 2017-09-15 00:00:00 (456.0 days) and wrote 315 records for ESU17 | 2018-12-19 08:39:12 HD Request # 148 | Completion time: 2s | 2018-12-19 08:39:12 HD Request # 148 | Daily data download complete for ESU17. Unique request ID: 146 | 2018-12-19 08:39:12 Removed historical data download ID 146 | 2018-12-19 08:39:12 HD Request # 149 | Downloading Historical Daily chart data for ESZ17. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:39:12 HD Request # 149 | Requesting historical Daily data for ESZ17 starting at 1968-12-17 | 2018-12-19 08:39:12 HD Request # 149 | Receiving historical Daily data for ESZ17 starting at 2016-09-16 | 2018-12-19 08:39:14 HD Request # 149 | Writing historical Daily data to the file ESZ17.dly | 2018-12-19 08:39:14 HD Request # 149 | Received 316 records from 2016-09-16 00:00:00 to 2017-12-15 00:00:00 (456.0 days) and wrote 316 records for ESZ17 | 2018-12-19 08:39:14 HD Request # 149 | Completion time: 2s | 2018-12-19 08:39:14 HD Request # 149 | Daily data download complete for ESZ17. Unique request ID: 147 | 2018-12-19 08:39:14 Removed historical data download ID 147 | 2018-12-19 08:39:14 HD Request # 150 | Downloading Historical Daily chart data for ESH18. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:39:14 HD Request # 150 | Requesting historical Daily data for ESH18 starting at 1968-12-17 | 2018-12-19 08:39:14 HD Request # 150 | Receiving historical Daily data for ESH18 starting at 2016-12-16 | 2018-12-19 08:39:16 HD Request # 150 | Writing historical Daily data to the file ESH18.dly | 2018-12-19 08:39:16 HD Request # 150 | Received 313 records from 2016-12-16 00:00:00 to 2018-03-16 00:00:00 (456.0 days) and wrote 313 records for ESH18 | 2018-12-19 08:39:16 HD Request # 150 | Completion time: 1s | 2018-12-19 08:39:16 HD Request # 150 | Daily data download complete for ESH18. Unique request ID: 148 | 2018-12-19 08:39:16 Removed historical data download ID 148 | 2018-12-19 08:39:16 HD Request # 151 | Downloading Historical Daily chart data for ESM18. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:39:16 HD Request # 151 | Requesting historical Daily data for ESM18 starting at 1968-12-17 | 2018-12-19 08:39:16 HD Request # 151 | Receiving historical Daily data for ESM18 starting at 2017-03-17 | 2018-12-19 08:39:17 HD Request # 151 | Writing historical Daily data to the file ESM18.dly | 2018-12-19 08:39:17 HD Request # 151 | Received 315 records from 2017-03-17 00:00:00 to 2018-06-15 00:00:00 (456.0 days) and wrote 315 records for ESM18 | 2018-12-19 08:39:17 HD Request # 151 | Completion time: 2s | 2018-12-19 08:39:17 HD Request # 151 | Daily data download complete for ESM18. Unique request ID: 149 | 2018-12-19 08:39:17 Removed historical data download ID 149 | 2018-12-19 08:39:17 HD Request # 152 | Downloading Historical Daily chart data for ESU18. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:39:17 HD Request # 152 | Requesting historical Daily data for ESU18 starting at 1968-12-17 | 2018-12-19 08:39:17 HD Request # 152 | Receiving historical Daily data for ESU18 starting at 2017-06-14 | 2018-12-19 08:39:19 HD Request # 152 | Writing historical Daily data to the file ESU18.dly | 2018-12-19 08:39:19 HD Request # 152 | Received 322 records from 2017-06-14 00:00:00 to 2018-09-21 00:00:00 (465.0 days) and wrote 322 records for ESU18 | 2018-12-19 08:39:19 HD Request # 152 | Completion time: 2s | 2018-12-19 08:39:19 HD Request # 152 | Daily data download complete for ESU18. Unique request ID: 150 | 2018-12-19 08:39:19 Removed historical data download ID 150 | 2018-12-19 08:39:19 HD Request # 153 | Downloading Historical Daily chart data for ESZ18. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:39:19 HD Request # 153 | Requesting historical Daily data for ESZ18 starting at 1968-12-17 | 2018-12-19 08:39:19 HD Request # 153 | Receiving historical Daily data for ESZ18 starting at 2017-09-13 | 2018-12-19 08:39:21 HD Request # 153 | Writing historical Daily data to the file ESZ18.dly | 2018-12-19 08:39:21 HD Request # 153 | Received 320 records from 2017-09-13 00:00:00 to 2018-12-19 00:00:00 (463.0 days) and wrote 320 records for ESZ18 | 2018-12-19 08:39:21 HD Request # 153 | Completion time: 1s | 2018-12-19 08:39:21 HD Request # 153 | Daily data download complete for ESZ18. Unique request ID: 151 | 2018-12-19 08:39:21 Removed historical data download ID 151 | 2018-12-19 08:39:21 HD Request # 154 | Downloading Historical Daily chart data for F.US.EPH19. Starting date: 1968-12-18. Service: cqg | 2018-12-19 08:39:21 HD Request # 154 | Requesting historical Daily data for ESH19 starting at 1968-12-17 | 2018-12-19 08:39:21 HD Request # 154 | Receiving historical Daily data for F.US.EPH19 starting at 2017-12-13 | 2018-12-19 08:39:22 HD Request # 154 | Writing historical Daily data to the file F.US.EPH19.dly | 2018-12-19 08:39:22 HD Request # 154 | Received 256 records from 2017-12-13 00:00:00 to 2018-12-19 00:00:00 (372.0 days) and wrote 256 records for F.US.EPH19 | 2018-12-19 08:39:22 HD Request # 154 | Completion time: 1s | 2018-12-19 08:39:22 HD Request # 154 | Daily data download complete for F.US.EPH19. Unique request ID: 152 | 2018-12-19 08:39:22 Removed historical data download ID 152 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Download is complete for all contract months in chart. Proceeding with data load. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Reloading chart. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Performing continuous futures contract back adjustment calculations. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPZ10 Open price on 2010-12-09 is 1228.5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPH11 Open price on 2010-12-09 is 1223.25. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPZ10 price difference to F.US.EPH11 is -5.25. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPH11 Open price on 2011-03-10 is 1315.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPM11 Open price on 2011-03-10 is 1311. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPH11 price difference to F.US.EPM11 is -4.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPM11 Open price on 2011-06-09 is 1277.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPU11 Open price on 2011-06-09 is 1273. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPM11 price difference to F.US.EPU11 is -4.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPU11 Open price on 2011-09-08 is 1199.25. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPZ11 Open price on 2011-09-08 is 1193.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPU11 price difference to F.US.EPZ11 is -5.5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPZ11 Open price on 2011-12-08 is 1263.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPH12 Open price on 2011-12-08 is 1257.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPZ11 price difference to F.US.EPH12 is -6. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPH12 Open price on 2012-03-08 is 1352.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPM12 Open price on 2012-03-08 is 1347. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPH12 price difference to F.US.EPM12 is -5.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPM12 Open price on 2012-06-07 is 1315.25. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPU12 Open price on 2012-06-07 is 1308.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPM12 price difference to F.US.EPU12 is -6.5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPU12 Open price on 2012-09-13 is 1438.25. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPZ12 Open price on 2012-09-13 is 1431.5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPU12 price difference to F.US.EPZ12 is -6.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPZ12 Open price on 2012-12-13 is 1425.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPH13 Open price on 2012-12-13 is 1419.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPZ12 price difference to F.US.EPH13 is -6. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPH13 Open price on 2013-03-07 is 1539.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPM13 Open price on 2013-03-07 is 1535. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPH13 price difference to F.US.EPM13 is -4.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPM13 Open price on 2013-06-13 is 1610.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPU13 Open price on 2013-06-13 is 1605. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPM13 price difference to F.US.EPU13 is -5.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPU13 Open price on 2013-09-12 is 1689.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPZ13 Open price on 2013-09-12 is 1683.25. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPU13 price difference to F.US.EPZ13 is -6.5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPZ13 Open price on 2013-12-12 is 1780.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPH14 Open price on 2013-12-12 is 1774.25. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPZ13 price difference to F.US.EPH14 is -6.5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPH14 Open price on 2014-03-13 is 1868.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPM14 Open price on 2014-03-13 is 1861.5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPH14 price difference to F.US.EPM14 is -7.25. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPM14 Open price on 2014-06-12 is 1943.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPU14 Open price on 2014-06-12 is 1936.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPM14 price difference to F.US.EPU14 is -7. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPU14 Open price on 2014-09-11 is 1994.5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPZ14 Open price on 2014-09-11 is 1986.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPU14 price difference to F.US.EPZ14 is -7.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPZ14 Open price on 2014-12-11 is 2026.25. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPH15 Open price on 2014-12-11 is 2019.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPZ14 price difference to F.US.EPH15 is -6.5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPH15 Open price on 2015-03-12 is 2042. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPM15 Open price on 2015-03-12 is 2034.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPH15 price difference to F.US.EPM15 is -7.25. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPM15 Open price on 2015-06-11 is 2106. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPU15 Open price on 2015-06-11 is 2098.5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPM15 price difference to F.US.EPU15 is -7.5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPU15 Open price on 2015-09-10 is 1943.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPZ15 Open price on 2015-09-10 is 1934.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPU15 price difference to F.US.EPZ15 is -9. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPZ15 Open price on 2015-12-10 is 2045.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPH16 Open price on 2015-12-10 is 2037.25. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPZ15 price difference to F.US.EPH16 is -8.5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPH16 Open price on 2016-03-10 is 1990. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPM16 Open price on 2016-03-10 is 1981. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPH16 price difference to F.US.EPM16 is -9. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPM16 Open price on 2016-06-09 is 2117.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPU16 Open price on 2016-06-09 is 2108.5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPM16 price difference to F.US.EPU16 is -9.25. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPU16 Open price on 2016-09-08 is 2184.5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPZ16 Open price on 2016-09-08 is 2178. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPU16 price difference to F.US.EPZ16 is -6.5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPZ16 Open price on 2016-12-08 is 2236.5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPH17 Open price on 2016-12-08 is 2231.25. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPZ16 price difference to F.US.EPH17 is -5.25. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPH17 Open price on 2017-03-09 is 2363.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPM17 Open price on 2017-03-09 is 2360.25. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPH17 price difference to F.US.EPM17 is -3.5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPM17 Open price on 2017-06-08 is 2431.5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPU17 Open price on 2017-06-08 is 2430.25. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Adjusting price difference from -1.25 by user specified amount of -1 to -2.25 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPM17 price difference to F.US.EPU17 is -2.25. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPU17 Open price on 2017-09-07 is 2464. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPZ17 Open price on 2017-09-07 is 2462.25. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPU17 price difference to F.US.EPZ17 is -1.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPZ17 Open price on 2017-12-07 is 2630.5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPH18 Open price on 2017-12-07 is 2633.25. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPZ17 price difference to F.US.EPH18 is 2.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPH18 Open price on 2018-03-08 is 2722.5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPM18 Open price on 2018-03-08 is 2728.5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Adjusting price difference from 6 by user specified amount of -1 to 5 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPH18 price difference to F.US.EPM18 is 5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPM18 Open price on 2018-06-07 is 2773.25. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPU18 Open price on 2018-06-07 is 2777.5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Adjusting price difference from 4.25 by user specified amount of -0.5 to 3.75 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPM18 price difference to F.US.EPU18 is 3.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPU18 Open price on 2018-09-13 is 2887. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPZ18 Open price on 2018-09-13 is 2892.5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Adjusting price difference from 5.5 by user specified amount of -0.5 to 5 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPU18 price difference to F.US.EPZ18 is 5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPZ18 Open price on 2018-12-13 is 2653. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPH19 Open price on 2018-12-13 is 2657.25. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Adjusting price difference from 4.25 by user specified amount of -0.25 to 4 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | F.US.EPZ18 price difference to F.US.EPH19 is 4. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPZ10 is -152.5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPH11 is -147.25. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPM11 is -142.5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPU11 is -137.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPZ11 is -132.25. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPH12 is -126.25. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPM12 is -120.5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPU12 is -114. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPZ12 is -107.25. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPH13 is -101.25. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPM13 is -96.5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPU13 is -90.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPZ13 is -84.25. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPH14 is -77.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPM14 is -70.5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPU14 is -63.5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPZ14 is -55.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPH15 is -49.25. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPM15 is -42. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPU15 is -34.5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPZ15 is -25.5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPH16 is -17. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPM16 is -8. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPU16 is 1.25. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPZ16 is 7.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPH17 is 13. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPM17 is 16.5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPU17 is 18.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPZ17 is 20.5. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPH18 is 17.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPM18 is 12.75. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPU18 is 9. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPZ18 is 4. | 2018-12-19 08:39:22 Chart #14 has tagged chart #20 for full recalculation. Chartbook: ES.cht | 2018-12-19 08:39:22 Chart #14 has tagged chart #22 for full recalculation. Chartbook: ES.cht | 2018-12-19 08:39:22 Chart #14 has tagged chart #24 for full recalculation. Chartbook: ES.cht | 2018-12-19 08:39:22 Chart #14 has tagged chart #31 for full recalculation. Chartbook: ES.cht | 2018-12-19 08:39:22 Chart #14 has tagged chart #33 for full recalculation. Chartbook: ES.cht | 2018-12-19 08:39:22 Chart #14 has tagged chart #4 for full recalculation. Chartbook: ES.cht | 2018-12-19 08:39:22 Chart #14 has tagged chart #20 for full recalculation. Chartbook: ES.cht | 2018-12-19 08:39:22 Chart #14 has tagged chart #22 for full recalculation. Chartbook: ES.cht | 2018-12-19 08:39:22 Chart #14 has tagged chart #24 for full recalculation. Chartbook: ES.cht | 2018-12-19 08:39:22 Chart #14 has tagged chart #31 for full recalculation. Chartbook: ES.cht | 2018-12-19 08:39:22 Chart #14 has tagged chart #33 for full recalculation. Chartbook: ES.cht | 2018-12-19 08:39:22 Chart #14 has tagged chart #4 for full recalculation. Chartbook: ES.cht | 2018-12-19 08:39:22 Chart #14 has tagged chart #20 for full recalculation. Chartbook: ES.cht | 2018-12-19 08:39:22 Chart #14 has tagged chart #22 for full recalculation. Chartbook: ES.cht | 2018-12-19 08:39:22 Chart #14 has tagged chart #24 for full recalculation. Chartbook: ES.cht | 2018-12-19 08:39:22 Chart #14 has tagged chart #31 for full recalculation. Chartbook: ES.cht | 2018-12-19 08:39:22 Chart #14 has tagged chart #33 for full recalculation. Chartbook: ES.cht | 2018-12-19 08:39:22 Chart #14 has tagged chart #4 for full recalculation. Chartbook: ES.cht | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Reloading chart. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPZ10 to next contract occurs at 2010-12-09. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPH11 to next contract occurs at 2011-03-10. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPM11 to next contract occurs at 2011-06-09. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPU11 to next contract occurs at 2011-09-08. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPZ11 to next contract occurs at 2011-12-08. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPH12 to next contract occurs at 2012-03-08. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPM12 to next contract occurs at 2012-06-07. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPU12 to next contract occurs at 2012-09-13. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPZ12 to next contract occurs at 2012-12-13. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPH13 to next contract occurs at 2013-03-07. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPM13 to next contract occurs at 2013-06-13. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPU13 to next contract occurs at 2013-09-12. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPZ13 to next contract occurs at 2013-12-12. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPH14 to next contract occurs at 2014-03-13. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPM14 to next contract occurs at 2014-06-12. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPU14 to next contract occurs at 2014-09-11. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPZ14 to next contract occurs at 2014-12-11. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPH15 to next contract occurs at 2015-03-12. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPM15 to next contract occurs at 2015-06-11. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPU15 to next contract occurs at 2015-09-10. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPZ15 to next contract occurs at 2015-12-10. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPH16 to next contract occurs at 2016-03-10. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPM16 to next contract occurs at 2016-06-09. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPU16 to next contract occurs at 2016-09-08. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPZ16 to next contract occurs at 2016-12-08. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPH17 to next contract occurs at 2017-03-09. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPM17 to next contract occurs at 2017-06-08. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPU17 to next contract occurs at 2017-09-07. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPZ17 to next contract occurs at 2017-12-07. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPH18 to next contract occurs at 2018-03-08. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPM18 to next contract occurs at 2018-06-07. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPU18 to next contract occurs at 2018-09-13. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPZ18 to next contract occurs at 2018-12-13. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Date rule based rollover from F.US.EPH19 to next contract occurs at 2019-03-07. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol ESZ10 for the date range from 2010-09-09 to 2010-12-09. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol ESH11 for the date range from 2010-12-09 to 2011-03-10. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol ESM11 for the date range from 2011-03-10 to 2011-06-09. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol ESU11 for the date range from 2011-06-09 to 2011-09-08. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol ESZ11 for the date range from 2011-09-08 to 2011-12-08. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol ESH12 for the date range from 2011-12-08 to 2012-03-08. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-07. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-13. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-03-12. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol ESM15 for the date range from 2015-03-12 to 2015-06-11. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol ESU15 for the date range from 2015-06-11 to 2015-09-10. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol ESZ15 for the date range from 2015-09-10 to 2015-12-10. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol ESH16 for the date range from 2015-12-10 to 2016-03-10. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol ESM16 for the date range from 2016-03-10 to 2016-06-09. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol ESU16 for the date range from 2016-06-09 to 2016-09-08. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol ESZ16 for the date range from 2016-09-08 to 2016-12-08. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol ESH17 for the date range from 2016-12-08 to 2017-03-09. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol ESM17 for the date range from 2017-03-09 to 2017-06-08. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol ESU17 for the date range from 2017-06-08 to 2017-09-07. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol ESZ17 for the date range from 2017-09-07 to 2017-12-07. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol ESH18 for the date range from 2017-12-07 to 2018-03-08. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol ESM18 for the date range from 2018-03-08 to 2018-06-07. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol ESU18 for the date range from 2018-06-07 to 2018-09-13. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol ESZ18 for the date range from 2018-09-13 to 2018-12-13. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Checking Daily data file for symbol F.US.EPH19 for the date range from 2018-12-13 to 2018-12-19. | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file F.US.EPH19.dly. Date: 2018-12-13, Price: 2649.5. Date: 2018-12-19, Price: 2553 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file ESZ18.dly. Date: 2018-09-13, Price: 2910.25. Date: 2018-12-12, Price: 2652.5 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file ESU18.dly. Date: 2018-06-07, Price: 2776. Date: 2018-09-12, Price: 2888.5 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file ESM18.dly. Date: 2018-03-08, Price: 2744.25. Date: 2018-06-06, Price: 2772.25 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file ESH18.dly. Date: 2017-12-07, Price: 2642.25. Date: 2018-03-07, Price: 2723.25 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file ESZ17.dly. Date: 2017-09-07, Price: 2464.75. Date: 2017-12-06, Price: 2629.25 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file ESU17.dly. Date: 2017-06-08, Price: 2430.25. Date: 2017-09-06, Price: 2465.5 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file ESM17.dly. Date: 2017-03-09, Price: 2363.25. Date: 2017-06-07, Price: 2432 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file ESH17.dly. Date: 2016-12-08, Price: 2242.5. Date: 2017-03-08, Price: 2364 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file ESZ16.dly. Date: 2016-09-08, Price: 2171. Date: 2016-12-07, Price: 2236.75 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file ESU16.dly. Date: 2016-06-09, Price: 2105.25. Date: 2016-09-07, Price: 2184.5 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file ESM16.dly. Date: 2016-03-10, Price: 1979.5. Date: 2016-06-08, Price: 2118 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file ESH16.dly. Date: 2015-12-10, Price: 2041. Date: 2016-03-09, Price: 1989 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file ESZ15.dly. Date: 2015-09-10, Price: 1933.5. Date: 2015-12-09, Price: 2042 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file ESU15.dly. Date: 2015-06-11, Price: 2101.5. Date: 2015-09-09, Price: 1942.75 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file ESM15.dly. Date: 2015-03-12, Price: 2056.5. Date: 2015-06-10, Price: 2107 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file ESH15.dly. Date: 2014-12-11, Price: 2024. Date: 2015-03-11, Price: 2039.5 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file ESZ14.dly. Date: 2014-09-11, Price: 1989. Date: 2014-12-10, Price: 2026.5 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file ESU14.dly. Date: 2014-06-12, Price: 1923.25. Date: 2014-09-10, Price: 1995 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file ESM14.dly. Date: 2014-03-13, Price: 1839.75. Date: 2014-06-11, Price: 1944 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file ESH14.dly. Date: 2013-12-12, Price: 1768.5. Date: 2014-03-12, Price: 1867.75 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file ESZ13.dly. Date: 2013-09-12, Price: 1678.25. Date: 2013-12-11, Price: 1780.75 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file ESU13.dly. Date: 2013-06-13, Price: 1631. Date: 2013-09-11, Price: 1688.75 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file ESM13.dly. Date: 2013-03-07, Price: 1537.75. Date: 2013-06-12, Price: 1610 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file ESH13.dly. Date: 2012-12-13, Price: 1412. Date: 2013-03-06, Price: 1539 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file ESZ12.dly. Date: 2012-09-13, Price: 1432.5. Date: 2012-12-12, Price: 1427.25 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file ESU12.dly. Date: 2012-06-07, Price: 1310. Date: 2012-09-12, Price: 1439.5 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file ESM12.dly. Date: 2012-03-08, Price: 1360.5. Date: 2012-06-06, Price: 1315.5 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file ESH12.dly. Date: 2011-12-08, Price: 1230.25. Date: 2012-03-07, Price: 1352.75 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file ESZ11.dly. Date: 2011-09-08, Price: 1180. Date: 2011-12-07, Price: 1264 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file ESU11.dly. Date: 2011-06-09, Price: 1282. Date: 2011-09-07, Price: 1199 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file ESM11.dly. Date: 2011-03-10, Price: 1289.5. Date: 2011-06-08, Price: 1277 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file ESH11.dly. Date: 2010-12-09, Price: 1228. Date: 2011-03-09, Price: 1315.5 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Price data for daily data file ESZ10.dly. Date: 2010-09-09, Price: 1097.5. Date: 2010-12-08, Price: 1228.75 | 2018-12-19 08:39:22 F.US.EPH19 [CB] Daily #14 | Symbols used for continuous contract chart: | 2018-12-19 08:39:23 ESZ10 | 2018-12-19 08:39:23 ESH11 | 2018-12-19 08:39:23 ESM11 | 2018-12-19 08:39:23 ESU11 | 2018-12-19 08:39:23 ESZ11 | 2018-12-19 08:39:23 ESH12 | 2018-12-19 08:39:23 ESM12 | 2018-12-19 08:39:23 ESU12 | 2018-12-19 08:39:23 ESZ12 | 2018-12-19 08:39:23 ESH13 | 2018-12-19 08:39:23 ESM13 | 2018-12-19 08:39:23 ESU13 | 2018-12-19 08:39:23 ESZ13 | 2018-12-19 08:39:23 ESH14 | 2018-12-19 08:39:23 ESM14 | 2018-12-19 08:39:23 ESU14 | 2018-12-19 08:39:23 ESZ14 | 2018-12-19 08:39:23 ESH15 | 2018-12-19 08:39:23 ESM15 | 2018-12-19 08:39:23 ESU15 | 2018-12-19 08:39:23 ESZ15 | 2018-12-19 08:39:23 ESH16 | 2018-12-19 08:39:23 ESM16 | 2018-12-19 08:39:23 ESU16 | 2018-12-19 08:39:23 ESZ16 | 2018-12-19 08:39:23 ESH17 | 2018-12-19 08:39:23 ESM17 | 2018-12-19 08:39:23 ESU17 | 2018-12-19 08:39:23 ESZ17 | 2018-12-19 08:39:23 ESH18 | 2018-12-19 08:39:23 ESM18 | 2018-12-19 08:39:23 ESU18 | 2018-12-19 08:39:23 ESZ18 | 2018-12-19 08:39:23 F.US.EPH19 | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Performing continuous futures contract back adjustment calculations. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPZ10 Open price on 2010-12-09 is 1228.5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPH11 Open price on 2010-12-09 is 1223.25. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPZ10 price difference to F.US.EPH11 is -5.25. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPH11 Open price on 2011-03-10 is 1315.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPM11 Open price on 2011-03-10 is 1311. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPH11 price difference to F.US.EPM11 is -4.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPM11 Open price on 2011-06-09 is 1277.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPU11 Open price on 2011-06-09 is 1273. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPM11 price difference to F.US.EPU11 is -4.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPU11 Open price on 2011-09-08 is 1199.25. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPZ11 Open price on 2011-09-08 is 1193.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPU11 price difference to F.US.EPZ11 is -5.5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPZ11 Open price on 2011-12-08 is 1263.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPH12 Open price on 2011-12-08 is 1257.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPZ11 price difference to F.US.EPH12 is -6. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPH12 Open price on 2012-03-08 is 1352.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPM12 Open price on 2012-03-08 is 1347. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPH12 price difference to F.US.EPM12 is -5.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPM12 Open price on 2012-06-07 is 1315.25. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPU12 Open price on 2012-06-07 is 1308.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPM12 price difference to F.US.EPU12 is -6.5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPU12 Open price on 2012-09-13 is 1438.25. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPZ12 Open price on 2012-09-13 is 1431.5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPU12 price difference to F.US.EPZ12 is -6.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPZ12 Open price on 2012-12-13 is 1425.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPH13 Open price on 2012-12-13 is 1419.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPZ12 price difference to F.US.EPH13 is -6. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPH13 Open price on 2013-03-07 is 1539.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPM13 Open price on 2013-03-07 is 1535. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPH13 price difference to F.US.EPM13 is -4.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPM13 Open price on 2013-06-13 is 1610.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPU13 Open price on 2013-06-13 is 1605. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPM13 price difference to F.US.EPU13 is -5.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPU13 Open price on 2013-09-12 is 1689.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPZ13 Open price on 2013-09-12 is 1683.25. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPU13 price difference to F.US.EPZ13 is -6.5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPZ13 Open price on 2013-12-12 is 1780.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPH14 Open price on 2013-12-12 is 1774.25. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPZ13 price difference to F.US.EPH14 is -6.5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPH14 Open price on 2014-03-13 is 1868.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPM14 Open price on 2014-03-13 is 1861.5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPH14 price difference to F.US.EPM14 is -7.25. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPM14 Open price on 2014-06-12 is 1943.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPU14 Open price on 2014-06-12 is 1936.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPM14 price difference to F.US.EPU14 is -7. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPU14 Open price on 2014-09-11 is 1994.5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPZ14 Open price on 2014-09-11 is 1986.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPU14 price difference to F.US.EPZ14 is -7.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPZ14 Open price on 2014-12-11 is 2026.25. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPH15 Open price on 2014-12-11 is 2019.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPZ14 price difference to F.US.EPH15 is -6.5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPH15 Open price on 2015-03-12 is 2042. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPM15 Open price on 2015-03-12 is 2034.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPH15 price difference to F.US.EPM15 is -7.25. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPM15 Open price on 2015-06-11 is 2106. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPU15 Open price on 2015-06-11 is 2098.5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPM15 price difference to F.US.EPU15 is -7.5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPU15 Open price on 2015-09-10 is 1943.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPZ15 Open price on 2015-09-10 is 1934.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPU15 price difference to F.US.EPZ15 is -9. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPZ15 Open price on 2015-12-10 is 2045.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPH16 Open price on 2015-12-10 is 2037.25. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPZ15 price difference to F.US.EPH16 is -8.5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPH16 Open price on 2016-03-10 is 1990. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPM16 Open price on 2016-03-10 is 1981. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPH16 price difference to F.US.EPM16 is -9. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPM16 Open price on 2016-06-09 is 2117.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPU16 Open price on 2016-06-09 is 2108.5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPM16 price difference to F.US.EPU16 is -9.25. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPU16 Open price on 2016-09-08 is 2184.5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPZ16 Open price on 2016-09-08 is 2178. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPU16 price difference to F.US.EPZ16 is -6.5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPZ16 Open price on 2016-12-08 is 2236.5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPH17 Open price on 2016-12-08 is 2231.25. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPZ16 price difference to F.US.EPH17 is -5.25. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPH17 Open price on 2017-03-09 is 2363.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPM17 Open price on 2017-03-09 is 2360.25. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPH17 price difference to F.US.EPM17 is -3.5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPM17 Open price on 2017-06-08 is 2431.5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPU17 Open price on 2017-06-08 is 2430.25. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Adjusting price difference from -1.25 by user specified amount of -1 to -2.25 | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPM17 price difference to F.US.EPU17 is -2.25. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPU17 Open price on 2017-09-07 is 2464. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPZ17 Open price on 2017-09-07 is 2462.25. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPU17 price difference to F.US.EPZ17 is -1.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPZ17 Open price on 2017-12-07 is 2630.5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPH18 Open price on 2017-12-07 is 2633.25. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPZ17 price difference to F.US.EPH18 is 2.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPH18 Open price on 2018-03-08 is 2722.5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPM18 Open price on 2018-03-08 is 2728.5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Adjusting price difference from 6 by user specified amount of -1 to 5 | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPH18 price difference to F.US.EPM18 is 5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPM18 Open price on 2018-06-07 is 2773.25. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPU18 Open price on 2018-06-07 is 2777.5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Adjusting price difference from 4.25 by user specified amount of -0.5 to 3.75 | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPM18 price difference to F.US.EPU18 is 3.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPU18 Open price on 2018-09-13 is 2887. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPZ18 Open price on 2018-09-13 is 2892.5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Adjusting price difference from 5.5 by user specified amount of -0.5 to 5 | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPU18 price difference to F.US.EPZ18 is 5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPZ18 Open price on 2018-12-13 is 2653. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPH19 Open price on 2018-12-13 is 2657.25. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Adjusting price difference from 4.25 by user specified amount of -0.25 to 4 | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | F.US.EPZ18 price difference to F.US.EPH19 is 4. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPZ10 is -152.5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPH11 is -147.25. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPM11 is -142.5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPU11 is -137.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPZ11 is -132.25. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPH12 is -126.25. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPM12 is -120.5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPU12 is -114. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPZ12 is -107.25. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPH13 is -101.25. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPM13 is -96.5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPU13 is -90.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPZ13 is -84.25. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPH14 is -77.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPM14 is -70.5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPU14 is -63.5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPZ14 is -55.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPH15 is -49.25. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPM15 is -42. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPU15 is -34.5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPZ15 is -25.5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPH16 is -17. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPM16 is -8. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPU16 is 1.25. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPZ16 is 7.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPH17 is 13. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPM17 is 16.5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPU17 is 18.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPZ17 is 20.5. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPH18 is 17.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPM18 is 12.75. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPU18 is 9. | 2018-12-19 08:39:23 F.US.EPH19 [CB] Daily #14 | Back adjust amount for symbol F.US.EPZ18 is 4. | 2018-12-19 08:39:23 F.US.EPH19 [CB] 30 Min #31 | Performing a full recalculation because it has been tagged. Chartbook: ES.cht | 2018-12-19 08:39:23 Chart #14 has tagged chart #20 for full recalculation. Chartbook: ES.cht | 2018-12-19 08:39:23 Chart #14 has tagged chart #22 for full recalculation. Chartbook: ES.cht | 2018-12-19 08:39:23 Chart #14 has tagged chart #24 for full recalculation. Chartbook: ES.cht | 2018-12-19 08:39:23 Chart #14 has tagged chart #31 for full recalculation. Chartbook: ES.cht | 2018-12-19 08:39:23 Chart #14 has tagged chart #33 for full recalculation. Chartbook: ES.cht | 2018-12-19 08:39:23 Chart #14 has tagged chart #4 for full recalculation. Chartbook: ES.cht | 2018-12-19 08:39:23 Chart #14 has tagged chart #20 for full recalculation. Chartbook: ES.cht | 2018-12-19 08:39:23 Chart #14 has tagged chart #22 for full recalculation. Chartbook: ES.cht | 2018-12-19 08:39:23 Chart #14 has tagged chart #24 for full recalculation. Chartbook: ES.cht | 2018-12-19 08:39:23 Chart #14 has tagged chart #31 for full recalculation. Chartbook: ES.cht | 2018-12-19 08:39:23 Chart #14 has tagged chart #33 for full recalculation. Chartbook: ES.cht | 2018-12-19 08:39:23 Chart #14 has tagged chart #4 for full recalculation. Chartbook: ES.cht | 2018-12-19 08:39:23 F.US.EPH19 [CB] 60 Min #33 | Performing a full recalculation because it has been tagged. Chartbook: ES.cht | 2018-12-19 08:39:23 F.US.EPH19 [CB] 5 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: ES.cht | 2018-12-19 08:39:23 Chart #4 has tagged chart #6 for full recalculation. Chartbook: ES.cht | 2018-12-19 08:39:23 F.US.EPH19 1 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: ES.cht | 2018-12-19 08:39:23 F.US.EPH19 [CB] 2500 Volume #20 | Performing a full recalculation because it has been tagged. Chartbook: ES.cht | 2018-12-19 08:39:23 F.US.EPH19 [CB] 240 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: ES.cht | 2018-12-19 08:39:23 F.US.RTYH19 [CB] 2 Min #24 | Performing a full recalculation because it has been tagged. Chartbook: ES.cht | 2018-12-19 08:39:23 F.US.EPH19 [CB] 30 Min #31 | Performing a full recalculation because it has been tagged. Chartbook: ES.cht | 2018-12-19 08:39:24 |
[2018-12-19 08:02:50] |
We do believe that there was a problem but it sounded like it was just a temporary historical data download issue. From what we can tell from this Message Log everything looks fine and you are confirming that as well. So at this point we consider this resolved. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
