Date/Time: Tue, 04 Nov 2025 14:57:39 +0000
Feature Request
View Count: 2894
|   [2013-03-21 06:27:30]     |
| rc7rader - Posts: 144 |
                Any thoughts on my feature request here - http://www.sierrachart.com/supportboard/showthread.php?p=235441#post235441. I have not received any reply if this is going to be considered or not. Thanks. |
|   [2013-03-21 06:50:22]     |
                We will do our best to implement this. It may not be so simple.
                 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2013-03-21 06:59:10]     |
                Good news.  We successfully implemented this.  It will be out in the next release.
                 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-03-21 06:59:25
|   [2013-03-21 16:27:31]     |
                That's good news. Thanks so much.
