Date/Time: Thu, 23 Jan 2025 05:05:43 +0000
Alert On Chart Drawing
View Count: 1283
[2018-11-14 15:12:43] |
User798620 - Posts: 29 |
Is there a way to get an alert on my Retracement tool? i use it to draw my FIB, i know other tools have alerts you can set, but is it possible on this one? if its not is there another comparable tool that i could use for that? thanks in advance!
[2018-11-14 18:41:27] |
Chart alerts are able to reference the Anchor points for Chart Drawings. This would mean that you could reference the 0% and 100% levels directly, or use those as part of a calculation to get other levels (i.e. =UDID[15].A1 * .85) would give you the 85% level assuming that anchor A1 is at the 100% level. Refer to the documentation here for how to do this: Study/Chart Alerts And Scanning: Referencing Chart Drawings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-14 18:41:38
