Date/Time: Sun, 19 May 2024 02:33:53 +0000
Bitmex Cross Leverage
View Count: 1443
[2018-11-14 11:33:21] |
User513228 - Posts: 41 |
Hi, You changed settings for Leverage in Bitmex´s DTS. How can i set Cross ? Everytime time is set 1x. I dont want 100x i want Cross |
[2018-11-14 17:15:54] |
Use a Leverage setting of 0. Here is the full documentation: https://www.sierrachart.com/index.php?page=doc/BitMEX_Trading.php#SettingBitmexLeverage Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-11-14 18:27:12] |
We do see a problem where even when you specify a leverage setting of 0, due to a validation it is getting set to .01. So it would change the leverage setting to .01 on the current positions. We are correcting that now.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-14 18:27:20
[2018-11-14 19:55:29] |
We have released version 1842 which resolves the issue. Just make sure that you set the Leverage setting in Global Settings >> Data/Trade Service Settings to 0. After the update you will need to change the leverage to what you want through the BitMex website for your existing positions. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-14 19:56:24
[2019-11-06 15:46:57] |
Jimmer - Posts: 2 |
Hi, I have a simple question relating to Bitmex Leverage. For example: if leverage is set through the global trade settings to 50x while I have an open position in XBT-XBTUSD this will change the leverage in that position to 50x. Will this also change the leverage for any new orders opened after for XBT-XBTUSD to 50x? |
[2019-11-06 16:35:48] |
The answer is yes and yes and is documented here: https://www.sierrachart.com/index.php?page=doc/BitMEX_Trading.php#SettingBitmexLeverage Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
