Date/Time: Wed, 22 Jan 2025 23:51:46 +0000
Tracking Data Adjustments
View Count: 586
[2018-11-01 18:48:13] |
Tom Wielgus - Posts: 7 |
Hi, Is there any way for me to review or look up the data adjustments I have made for mutual fund distributions, either for a particular symbol or for all symbols? Is there a file where data adjustments are stored? Thank you. |
[2018-11-01 19:52:48] |
No there is not but what we can do though is add a message to the Message Log and that message Log can be saved to a file by enabling the option for it in Global Settings >> General Settings. You can undo any adjustment with the following command: Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download".
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-01 19:53:34
