Date/Time: Tue, 04 Nov 2025 14:57:34 +0000
Candle Stick Patterns Finder
View Count: 4024
|   [2013-03-21 03:11:47]     |
| Avio - Posts: 14 |
                I’m using “CandleStick Patterns Finder” and “Color Bar Based on Alert Condition”. I would like to have let say all “Hammers” colored using the draw style “Color Bar” BUT I would like to get rid of the text under the bars. Is that possible and if so how can I achieve it? I tried hiding the study but it didn’t help.
|   [2013-03-21 06:01:54]     |
| Sawtooth - Posts: 4285 |
                To color the Hammers, use this formula in the Color Bar study: =ID1.SG1=1 =ID1.SG1 would also work. This assumes the CandleStick Patters Finder study is ID1, and the Pattern # is 1. Each Pattern # 1-6 is SG1-SG6, and it outputs a 1 when TRUE. Since neither Hide Study nor Draw Style Ignore will remove the text, set the color of Pattern 1 to match your chart background.  |
|   [2013-03-21 12:05:07]     |
| Avio - Posts: 14 |
                Thank you, Tom. I’ve tried matching the chart background before and didn’t like it because the invisible text ‘eats’ some of the next candle. I thought there was a way to remove the text completely. Anyway, thanks for the reply.
|   [2013-03-22 05:33:36]     |
                We will add an option to the next version of the Candlestick Patterns Finder study to hide the text.  The input name will be Display Text.
                 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
