Date/Time: Tue, 07 May 2024 19:48:21 +0000
NSE Data
View Count: 1907
[2018-10-09 15:25:59] |
User853510 - Posts: 1 |
Kindly suggest which data provide can be used for India exchange. Mostly looking for NSE. Thanks |
[2018-10-10 04:48:01] |
This is not yet supported but planned in the coming months if we can get some time to focus on this. We have just been very busy recently.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-10 04:48:17
[2018-10-11 00:35:09] |
But if you require just historical end of day daily data, we have that. You can find the symbol listing here: https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Stocks&ID=4#nse Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-19 17:30:35] |
rvdesh - Posts: 28 |
You may be aware that Auto-Trading is growing very fast in India, in particular on NSE Exchange. It would be great if Sierra Chart itself provides datafeed. Further, I have suggested to one of the new data service provide accelpix (https://www.accelpix.com/) to consider datafeed for sierra chart. The company is located at GIFT, future international financial hub of India. They may approach SC. Best of luck..
[2019-08-21 06:37:19] |
Ok thank you for this information.
[2020-11-27 02:06:01] |
NJ - Posts: 20 |
Any luck with this. Any data feed provider for India stocks apart from globaldatafeed?
[2020-11-27 02:47:49] |
Tried pursuing true data and and another dataptovider, but no luck so far. Any issues with Globaldatafeed? Delay in loading new symbol in nimble datapro is an issue. Some times it does not load the instrument only. I am ok with it but not very happy. However, customer care is very good. Date Time Of Last Edit: 2020-11-27 02:48:37
[2020-11-28 14:39:30] |
NJ - Posts: 20 |
Have you tried connecting Interactive Brokers for NSE Stock Data to Sierra Chart?
[2020-11-28 15:01:34] |
NJ - Posts: 20 |
Global data feed is expensive I felt and they only have 225 stock symbols. No such limitation with Interactive Brokers but unable to fetch the data into SC yet. Started another thread for that
[2020-11-28 15:45:25] |
NJ - Posts: 20 |
Sorry I didn't get that attached file. Could you mail it to me at nnjj2095@gmail.com if you are unable to attach here. Also I think I will need subscription to 'Market Data - Realtime' from IB? I currently have the delayed feed showing in TWS for NSE stocks and was wanting to test that in SC before i subsribe to real time. But I suppose I cant access even the delayed NSE data without subscription to 'Real Time Market Data' from IB. So u r finally using Global Data feed? Regards NJ |
[2020-11-28 16:02:12] |
NJ - Posts: 20 |
It says private file but there it is not hyperlinked to be able to download. I think you might want to uncheck the private file option
[2020-11-28 16:03:04] |
I have sent you email!!
[2020-11-28 16:05:45] |
NJ - Posts: 20 |
Thanks a ton. I received that! Super helpful indeed!
[2020-11-28 16:06:58] |
You are welcome.......confirm once you are able to load symbols
[2020-11-28 16:09:57] |
NJ - Posts: 20 |
Surely. I will need to work with IB to get the real time data first. I am trying to reach them. Their support is down currently.
Date Time Of Last Edit: 2020-11-29 04:06:45
[2020-11-28 16:10:59] |
ok !
[2020-12-05 15:52:53] |
NJ - Posts: 20 |
I got the API connection from IB. Too many issues.. limit of 100 stocks + data connection between IB and Sierra is quite bad. Doesnt work properly at all. Tried Gobal Data Feed. Facing frequent disconnection issues from their data.. did u face the same? Regards Nitin |
