Date/Time: Wed, 22 Jan 2025 20:41:18 +0000
Chart Freezing Up
View Count: 1271
[2018-09-18 17:58:09] |
User596287 - Posts: 6 |
Every time i tried to add a new symbol like amzn-stk-smart the chart all froze and i have to restart Sierra Chart. Please help.
[2018-09-18 22:19:50] |
This does not really make sense to experience something like this with something like just opening a chart. We really would have to do a remote assistance session with you to see what is happening. Actually though we think we know what is happening. It might be caused by the Volume by Price study. Do you know if the Volume by Price study is on that chart or is automatically applied to a new chart? We would first want you to update to the current version of Sierra Chart following the instructions here: Software Download: Fast Update Here is more information about this issue: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.23 - Chart Tick Size and Volume at Price Processing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-19 16:34:27] |
I upgraded to the latest version but still not working. It seems to pick and choose which symbols work. AAPL and MU are fine but AMZN and NVDA are not working. I do have Volume by Price on one of the charts. The whole program froze NOT just one chart. To do a remote assistance, do i have to pay for your time? Thanks for your prompt reply.
[2018-09-19 21:17:39] |
It is the Volume by Price study which is the problem. This is thoroughly explained here: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.23 - Chart Tick Size and Volume at Price Processing Do not change the symbol of an existing chart to a symbol which has higher values, when the Volume by Price study is on that chart, until after you increase the Volume at Price Multiplier. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-19 21:17:59
[2018-10-24 22:46:56] |
I still have the same issue after increasing the "Volume at Price Multiplier". I am not sure if i doing it correctly. Now it's getting worst and i cant even switch from ES to NQ future without the whole program locked up and having to restart the program. Please help.
[2018-10-24 22:53:49] |
We do not know the configuration of that chart. We recommend just closing that chart and starting a new one and load a minimum amount of data in it. And with whatever you are doing, if there is that much processing involved, we recommend not changing the symbol of a chart and just using a separate chart. But not sure why this would really matter because the volume at price data is loaded in the background. Here is the relevant documentation: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.23 - Chart Tick Size and Volume at Price Processing High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.1 - Too Much Data to Load or Loaded Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-24 22:54:22
[2018-10-24 23:24:27] |
I am not sure if the volume at price is the problem. That is what you told me might be the problem. I didnt have a problem before so not sure why now. I cant delete the chart because its what I primarily trade with. Is it memory problem? Do i need to clear the cache or something? This is also happened after i signed up for CME data service through Sierra. I no longer have CME and receiving data feed from Interactive Broker. Could it be data configurations?
[2018-10-25 03:27:47] |
User750920 - Posts: 280 |
When I have an issue or want to test something out I will duplicate the chart - then delete what is or might be the problem and see what happens. That way the original chart is left intact in case I mess something up. Also for any study you can click on the settings and at the bottom there is a box to check that will says save these settings as default. Then when you remove the study you can add it back with the exact same settings. Again do this with the duplicate chart in case you make an error. Rename it too so there is no confusion.
[2018-10-25 19:14:49] |
We really need to get the chart that is causing a problem to understand what the problem might be from. Attach it here by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart We do not see how this is data feed related. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-25 19:15:37
[2018-10-25 19:19:42] |
It's not a chart that freezing up its the entire program when iam switching from symbol to symbol. Do you want the chart with the VBP?
[2018-10-25 19:21:17] |
Oh and i tried your recommendation with the process of elimination and hide the VBP studies or even closed out that chart entirely it still froze up.
[2018-10-26 00:25:15] |
Would be best to provide us the particular chart you are changing the symbol of. We will start the test with that. Here are instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
