Date/Time: Sun, 12 May 2024 19:16:16 +0000
Scale Padding % Default Value
View Count: 1030
[2018-09-07 13:52:53] |
User104854 - Posts: 441 |
Is there a way for me to set my own default value for this? It looks like it is currently at 2.000000. If I change it and then adjust the scale settings I have to keep changing it when I go back. If not can this please be added as an option to set the default? Please advise. Thanks.
[2018-09-08 01:48:31] |
No, this cannot be preset by the user. We will see about an option later on.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-08 01:48:42
[2021-03-04 17:50:07] |
User840539 - Posts: 21 |
Any updates on that option? Each time a new chart opens, the upper or lower values are barely visible (using Numbers Bars). Would be great to have a Default Scale Padding % for all charts. Thank you!
[2021-03-04 20:33:00] |
There is a Default Scale Padding Percentage that can be set in the Scale Settings window. But it is chart specific. It is not a global setting. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-22 12:06:47] |
pismo10 - Posts: 158 |
"There is a Default Scale Padding Percentage that can be set in the Scale Settings window. But it is chart specific. It is not a global setting" How? |
[2024-03-22 15:26:40] |
John - SC Support - Posts: 31555 |
On the Scale Settings is an item for "Default Padding Percentage". Enter the value you want to have as your default in this field. Refer to the following: Chart Scale and Scale Adjusting: Default Scale Padding Percentage (Scale Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-22 15:38:04] |
Where is the question?
[2024-03-22 15:58:00] |
We are not understanding this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-22 16:48:09] |
How do i get to this option. Where is it? For example Global Settings >> General Settings >> etc... Where?? |
[2024-03-22 16:53:26] |
It is on the Scale Settings window. Refer to the other information on that page for how to access it.
[2024-03-22 17:00:53] |
Where is scale settings? Why are you making this so hard, just answer my question that I have asked over and over...
[2024-03-22 17:18:20] |
Everything is on the Scale Settings documentation page that we originally linked to in order to give you the information for the "Default Scale Padding Percentage". Scroll to the top of that page and look for the information you are wanting.
[2024-03-22 17:30:47] |
So now I get to waste time hunting around again instead of an expert giving me the info...Unbelievable..
[2024-03-22 17:58:25] |
You have already spent more time waiting on us to answer your question than it would have taken you to find it. It is not our job to tell you exactly how to do something. It is our job to point you to the information on how to do something.
