Date/Time: Tue, 04 Nov 2025 14:58:13 +0000
[User Discussion] - Floating toolbar always on top?
View Count: 2651
[2013-04-07 03:41:45]
joshtrader - Posts: 526
Is it possible to make a floating toolbar always on top? I have found only one way to kludge this--if I do Window->Toolbar->1, when it first appears, I can use an external program called "Window On Top" which I already use to make this work. But if I open the floating toolbar window and then click another window anywhere else, I can't get even this method to work, since the floating toolbar never seems to have its own separate focus (in other words, there's always another sierra window that seems to have the focus). So, is there some way to do this more easily that I'm missing?
