Date/Time: Tue, 21 Jan 2025 10:58:30 +0000
Chart shifting
View Count: 1160
[2018-08-15 13:59:55] |
User103861 - Posts: 42 |
I have a 2 tick renko chart and a 5 min numbers bar chart (both ES_F). On every tick higher/lower, the entire chart shifts up or down (happens on both charts). I have reset, and locked the scale and tried every possible scale configuration to see if it helps but it has had no effect. Please advise how to stop this.
[2018-08-15 17:10:08] |
Make sure the Scale Range is set to Automatic. Follow the instructions here in regards to this: Chart Scale and Scale Adjusting: Chart Bars or Studies Not Completely within View, Not Displayed, or Cut Off. Reset Scales. Also, on the Scale, you could use the option Scale Range: User Defined with Auto Set from the Right-Click menu when you have the Scales set the way you want to see them? This is the easiest way to lock the scales at the current position, so they will not move anymore. This sets the scales to User Defined Range. The documentation for the above can be found here: Chart Scale and Scale Adjusting: Using Fixed Values for Top and Bottom of Scale Range Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-15 17:12:36
