Date/Time: Tue, 21 Jan 2025 07:23:50 +0000
I am unable to create charts that contain more than 12 years of data.
View Count: 713
[2018-08-09 19:52:35]
User747196 - Posts: 7
My interest is in relatively short term trading (day trading/ swing trading). For that, I use short term charts ranging from 5 ticks per "range bar" up to 40 ticks per "range bar", and daily charts.
I don't need more than a few days ( or weeks) of data for that purpose.
However, I would like to be able to download data for a few very long term charts. For example, the Dow Jones Industrial Average.
I tried to download 100 years of monthly data for the Dow from Sierra Chart, but was unable to get more than 12 years of data.
Am I doing something wrong, or is 12 years the maximum that Sierra Chart provides?
Thanks for your help.
Peter
(By the way, this is important to me. If you "Decline Support" on this issue, then I will be declining my Sierra Chart subscription.)
[2018-08-09 22:41:32]
There is a limit to the data depending on the symbol. Historical daily data for the Dow Jones goes back more than 12 years though. It goes back to 1968-08-09. Use the symbol: $DOWI
Refer to:
No Historical Chart or Blank Chart | Historical Chart Not Updating | Missing Historical Chart Data: 6.4: Missing Data in a Historical Chart Due to the Days to Load Setting to Low
Also, we would not decline support, but if there is data you need which is not available then we really cannot help with it other than to recommend to find it somewhere else in a downloadable format and then you can use it within Sierra Chart as explained here:
Text/CSV Data Format
But best just to let us know the particular symbol first.
Date Time Of Last Edit: 2018-08-09 22:43:03
