Date/Time: Tue, 04 Nov 2025 09:19:30 +0000
Delay in quotes when lot's of charts are opened
View Count: 850
|   [2018-08-09 10:32:00]     |
| smeb - Posts: 10 |
                Hello, I realize that there is some big delays (up to 20-30 seconds) in ticks. I do my test with EURUSD, M1, using Data Service Settings : "SC Forex Data (FXCM)". If I launch one sierrachart with one chart, it ticks normally. If I launch my sierrachart with lots of charts then there is that delay. The computer CPU is busy but far from 100%. To take the best decision, I'd like to understand what/where the limit is. - Is it because there is too many charts with the same account ? Is there a limit ? - Is it because there is too many charts in the same sierra chart instance ? - Other limitations ? Maybe some settings can fix this ? Thanks a lot for your help. Regards,  |
|   [2018-08-09 20:41:12]     |
                There are no limits, but you might want to use an additional instance of Sierra Chart.  Refer to: Using DTC Server for Data and Trading in Another Sierra Chart Instance Also refer to help topic 30: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
