Date/Time: Tue, 21 Jan 2025 00:55:11 +0000
User835156 Sierra Chart do not start
View Count: 771
[2018-07-23 12:26:53] |
User835156 - Posts: 3 |
With this login « ericmary" I succed to have a new password but Sierra Chart does not start anyway Can you help me please ? bests Eric Date Time Of Last Edit: 2018-07-23 16:24:32
[2018-07-23 16:35:32] |
We need to understand this better. When you start Sierra Chart using the shortcut on your computer desktop, do you see the Login window? And then after that the main window. If you see the login window, then the question we have is whether you are unable to login to the Sierra Chart charting and trading software, or unable to connect to the data feed/trade server. For help to answer this question, please review help topic number 62 here: Software Login or Data Feed Connection Problem Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-23 16:35:59
