Date/Time: Mon, 20 Jan 2025 08:23:41 +0000
Multiple Charts with Tabs
View Count: 1366
[2018-06-04 19:25:05]
User311951 - Posts: 31
Since I have multiple screens, I like to detach charts and have different asset classes on different screens.
I want each screen to display the following for its asset class:
Tab1 = Numbers bar chart for asset class 1
Tab2 = 30 min chart for asset class 1
Unfortunately I am struggling to have charts with multiple tabs if they are detached from the control centre.
Can I have this type of chart on each of my three screens or is it only possible to have multiple tabs on a chart if it is attached to the control centre?
Many Thanks,
Shayaan
[2018-06-04 20:02:01]
You need to use multiple instances of Sierra Chart:
Using DTC Server for Data and Trading in Another Sierra Chart Instance
