Date/Time: Tue, 04 Nov 2025 14:59:33 +0000
Possible to create a OHLC chart from Bid Ask as well as Traded q
View Count: 3445
|   [2013-04-05 21:20:01]     |
| User22396 - Posts: 191 |
                Is it possible to create an intraday OHLC chart from the Bid & Ask quotes? thanks b  |
|   [2013-04-05 21:30:44]     |
                Refer to this page: http://www.sierrachart.com/index.php?l=doc/doc_RecordingModes.php Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2013-04-05 23:04:05]     |
                great thanks
