Date/Time: Sun, 19 Jan 2025 22:01:12 +0000
UseTool drawing and duplicating chart
View Count: 662
[2018-05-21 13:55:39] |
@sstfrederik - Posts: 405 |
Hi SC Engineering, In some custom study I draw something on a chart with UseTool and set AddAsUserDrawnDrawing to true. When the chart with this study is duplicated I end up with two userdrawings on that chart. This is happening because the LineNumber for that study starts as zero on the new chart so the study draws a new drawing, and the original drawing is duplicated in the chart duplication process. The result is that I lose control of the duplicated drawing and this drawing also remains visible when the study is removed. Any tips to manage this? Kind regards, Frederik |
[2018-05-21 17:56:04] |
We assume this happens because you are saving the line numbers in persistent variables and those are cleared when a chart is duplicated. The only thing we can think is to store the line number in sc.StorageBlock. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
