Date/Time: Sun, 19 Jan 2025 23:25:30 +0000
[Locked] - Upgrading from 1689
View Count: 683
[2018-05-18 13:03:31] |
Sporken - Posts: 82 |
Hi, Am I correct in thinking that the "Current Version" (v1746 today), is the same as the "Pre-Release" version plus some extra change(s)? Are the pre-release features kept out of the Current release branch until they're stable? I've held off from updating since pre-christmas because I'm never sure if the Current version is stable or not. I don't want pre-release features until they're 100% reliable. Thanks for your help, -Jason Date Time Of Last Edit: 2018-05-18 13:10:21
[2018-05-18 18:25:03] |
No this is not correct. Both the current release and pre-release are always stable. It is a rare exception that there is any genuine instability. Sometimes there are some issues with new features, or an area of the program we worked on that did not get caught in testing because we cannot always be aware of all usage scenarios but those would get resolved promptly once we are aware of them. It is a rare exception, that there is any genuine stability issue with a current version or prerelease. And the likelihood of encountering a genuine stability issue is the same whether it is a current version or prerelease. And as we said, these are rare. And we continuously make improvements to avoid these to begin with. Refer to: http://www.sierrachart.com/index.php?page=doc/SoftwareDownload.php#AboutPrereleases Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-19 23:19:58
