Date/Time: Sun, 19 Jan 2025 17:58:07 +0000
Problem with LINE TOOL - its been a week since this tool makes only horizontal and vertica
View Count: 781
[2018-05-01 15:04:02] |
User617097 - Posts: 1 |
Problem with LINE TOOL - its been a week since this tool makes ONLY horizontal and vertical line i can not make line what i want to !!! |
[2018-05-01 17:43:28] |
This would indicate that the Control key keyboard state is locked on, on your system for some reason.
[2018-05-01 17:44:10] |
The first two things to check are the following: 1. Have you checked the box on the configuration for the Line Tool for Use Fixed Angle? The documentation on this item is here: Chart Drawing Tools: Line | Ray | Extended Line Configuration 2. When holding down the Ctrl key, the line tool only allows Horizontal and Vertical lines. Be sure the Ctrl key is not being pressed, or is not stuck somehow. You can find the documentation for this here: Chart Drawing Tools: Line, Ray, Extended Line Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
