Date/Time: Sun, 19 Jan 2025 21:47:07 +0000
Cant place orders via CTS
View Count: 1650
[2018-05-01 11:34:14]
Adam - Posts: 141
Hi
im getting this error when trying to place CTS order via SC
CTS order update (Rejected). Info: CME:Order price is outside the limits 'Bid of 677700.00 violates High Limit of 7457.00'. Internal Order ID: 92008. Service Order ID: 6A5FC83B-E28C-4B0C-94F5-41CB6B38307E. Symbol: CL.20180600.CME_NY | 2018-05-01 11:32:14 *
[2018-05-01 17:24:14]
This error message originates from CTS. It is not anything we have any control over.
Is this for simulated trading?
[2018-05-01 19:24:49]
Adam - Posts: 141
No fully live im using the hardware pass through. Instance of t4 running and SC. If i place an order in T4 is appears in SC just can't place in SC.
Arnt you guys the same Firm?
[2018-05-01 19:25:47]
Adam - Posts: 141
Its basically sticking the decimals in 4 places to the right
[2018-05-01 19:39:11]
Follow the instructions here to apply the Symbol Settings to the chart or Trading DOM you are trading from:
http://www.sierrachart.com/index.php?page=doc/GlobalSymbolSettings.php#UpdateChartSettingsSteps
[2018-05-01 22:02:51]
Adam - Posts: 141
The plot thickens
it works fine on the primary instance of SC. it wont work on the substance..
ive clicked update symbols
using the exact same .cht on the primary i can trade on the sub its trying to place orders at 674400.00 instead of 67.44
[2018-05-02 00:54:24]
Did you alter the Global Symbol Settings for that symbol, in particular in the Real-time Multiplier? Or in the Chart Settings?
Date Time Of Last Edit: 2018-05-02 00:54:49
[2018-05-02 05:13:33]
Adam - Posts: 141
No its just CL not working as ES is fine. I even deleted and refreshed all symbols..
[2018-05-02 17:45:52]
OK we will do more testing today.
We just tested the ES and do not see a problem.
[2018-05-02 19:14:57]
We now see the reason for the issue. This will be resolved today.
This is a recent issue due to a change with the handling of the multiplier value for orders which inadvertently caused this problem.
[2018-05-02 19:50:36]
Adam - Posts: 141
thanks for the fix
[2018-05-03 19:10:49]
Adam - Posts: 141
Hi i upgraded to 1738 on all instances and the same error on CL and now also doing it on ES
CTS T4 FIX order update (Order reject). Info: CTS order update (Rejected). Info: CME:Order price is outside the limits 'Bid of 683400.00 violates High Limit of 7393.00'. Internal Order ID: 77927. Service Order ID: 93492. Symbol: CL.20180600.CME_NY | 2018-05-03 19:09:18 *
CTS T4 FIX order update (Order reject). Info: CTS order update (Rejected). Info: CME:Order price is outside bands 'Bid of 26240000.00 violates High Band 263125.00 using Delta .00, C.Last equals 262525.00'. Internal Order ID: 77928. Service Order ID: 93493. Symbol: ES.20180600.CME_Eq | 2018-05-03 19:10:15 *
[2018-05-03 19:18:32]
User948528 - Posts: 108
Still occurring on 1740 in sub instances.
[2018-05-03 19:24:28]
Yes we would expect that it would occur with ES as well. We still have not yet released a new version.
We need to think about the solution carefully.
[2018-05-03 19:30:25]
Adam - Posts: 141
sorry i was jsut going off tags #9 #10
and wanted to make sure i had not messed something up my end
[2018-05-04 03:44:45]
The resolution of this problem is involved because it requires comprehensive review and testing. We expect to get it out by morning.
[2018-05-21 15:04:17]
Resolved?
[2018-05-21 16:10:56]
Yes it is.
