Date/Time: Sun, 19 Jan 2025 18:00:37 +0000
Not connecting to Bitmex server
View Count: 1155
[2018-04-30 08:24:21] |
User998694 - Posts: 1 |
Hi, my Sierra chart is not connecting to my bitmex server. It was working perfectly fine laat week however began lacking on the weekened. Could you offer any assistance? Cheers. Below I have attached a screenshot of the log. https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=18944 |
[2018-04-30 18:20:19] |
This is not something we can help with. This is a BitMEX server issue. However, what you should do in this case is select File >> Disconnect, wait about two hours and try connecting again with File >> Connect to Data Feed. We are going to be working on a new connection model to BitMEX to work around this but it is not likely to get done for another month. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-30 18:23:39
