Date/Time: Thu, 26 Nov 2026 04:09:33 +0000
[User Discussion] - Draw Horizontal Lines Multiple charts
View Count: 3419
| [2018-04-24 20:05:18] |
| User375840 - Posts: 7 |
Is there a way to LINK Horizontal lines across All charts of the SAME symbol? (example) If I draw a line on my ES 2000 Tick chart at 2610.25, I'd like the line to copy on my 1000 ES Tick chart and my 5 minute ES chart at the same price of 2610.25 |
| [2018-04-24 20:27:12] |
Yes. Refer to: Copying Chart Drawings from Other Charts Automatically Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-11-14 06:29:04] |
| User519569 - Posts: 18 |
The limiting factor here, as best I can tell, is that you can only draw S/R lines on a chart of lower times (like a 15 min chart) to a chart of a higher time (like an hour chart) unless you can figure out a way to set the 15 minute chart's starting date and time to an earlier date and time than the hour chart's starting date and time. I'm still chugging away at this problem. Plus it won't work if you use strange candle types, or so I've read. |
