Date/Time: Tue, 21 Jan 2025 07:24:32 +0000
Spread 3 Chart Description
View Count: 1269
[2018-04-24 08:19:08]
User740496 - Posts: 32
I am using the Spread 3 Charts study - when I select it as Main Price Graph, it works fine except that the chart description stays with the original, and does not change to show the description for the 3 Chart study. I have ticked all the check boxes in the study for showing names, descriptions, values etc and these show up when it is a separate study. Just does not transfer when displaying as Main Price Graph. I have tried using other studies as Main Price Graph and their descriptions always appear. What am I missing?
[2018-04-24 20:28:35]
We are looking this over. There is some additional programming required to support this.
[2018-05-04 07:25:08]
Just checking if this is now in your work schedule? Also previous thread re the alignment of Market Depth profile in DOM (text can be changed from left to right but visual volume profile appears anchored to one side) is this also in works? Thanks.
[2018-05-07 23:14:12]
This has not yet been looked at. We are very busy.
No. We did look into this and there have been no changes in this regard. This is how it has always been. So there is nothing further being done.
Date Time Of Last Edit: 2018-05-07 23:14:30
[2018-06-05 00:27:23]
In regards to the "Description", we want to make sure we understand what you are referring to. Provide an example of the description you are seeing and what you want to see instead.
[2018-06-07 08:58:41]
Using study "Spread - 3 Chart" I can create a Butterfly spread study to add to the price chart - in this case 5Y v 10Y v 30Y US Treasuries. It shows in Region 2 with normal description at top of chart showing the 3 instruments in the spread. Screenshot attached.
If I then select on the "Spread 3 Chart" settings to "Display as Main Price Graph" as don't need to see the input charts, the chart appears but the description from the study does not. See screenshot with spread chart now called the 10Y chart as that was the original/base. I tried adding a custom name/description in the study settings under "Short Name" but this does not display either. Hence Butterfly chart is now incorrectly called 10Y chart.
Summary - when using spread chart as main graph need correct description so that can tell what is being plotted. Either showing the 3 instruments or showing the short name (as may want to shorten the text with 3 instruments in one line, or show the ratio between the 3 instruments). Thanks.
http://www.sierrachart.com/image.php?Image=1528361764112.png
http://www.sierrachart.com/image.php?Image=1528361798748.png
[2018-08-06 17:42:33]
The information can be displayed. You can configure what is displayed in the Chart Header. Refer to this section of the documentation:
Working With Charts: Region Data Line / Chart Header
Make sure you add the field Symbol-Bar Period-Chart #.
[2018-08-07 11:32:55]
Probably missing something but cannot get this to work. I can see data in regional line when study is shown in region 3, but if i select study to be shown as Main Display the regional line still shows region 1 info not region 3?
[2018-08-07 17:26:08]
What are the header items which are set to be displayed in Global Settings >> Customize Chart Header?
